im85288 1493 Posted April 10, 2014 Posted April 10, 2014 Luke as promised here is the issue I and at least one other user (from the XBMB3C thread) have been experiencing with regards to the Primary Image being scrapped as a Banner rather than a Poster. I did not initially report this due to running the server on OS X but now the other user has reported it too and they are using the server on Windows. What I have found is that when TV shows are scrapped it creates a bunch of metadata and in particular a poster.jpg for the primary image. Initially this is fine, but through the night or whenever the daily schedule runs this primary image get's overwritten with a Banner resulting in the poster.jpg looking like it is suffering from low pixels. To circumvent this I have to go to each TV show and copy/paste the correct poster.jpg to another file called folder.jpg. With the folder.jpg file present the primary image no longer get's overwritten with the incorrect Banner image when the daily update occurs. The same principle applies to Movies too. One other thing that happens with the OS X version (I have not tested to see if this occurs on Windows) is the CoverArt plugin takes a "slice" out of the artwork. For example:
im85288 1493 Posted April 10, 2014 Author Posted April 10, 2014 Thanks for the explanation, would it be possible to get a treatment style for People that does not have the gloss overlay?
ebr 16306 Posted April 10, 2014 Posted April 10, 2014 doesn't like or may very well just not be implemented. It is an image I am drawing on top of the treatment. Something about that image OSX doesn't like and it isn't rendering properly. Thanks for the explanation, would it be possible to get a treatment style for People that does not have the gloss overlay? What happens if you select the Sapphire treatment?
im85288 1493 Posted April 10, 2014 Author Posted April 10, 2014 Sapphire treatment has a similar result: Just for completion here are the other two types available for Persons:
im85288 1493 Posted April 11, 2014 Author Posted April 11, 2014 I have not checked that actually, will have a look and confirm either way.
im85288 1493 Posted April 11, 2014 Author Posted April 11, 2014 No the slice does not occur without the CoverArt plugin installed:
ebr 16306 Posted April 11, 2014 Posted April 11, 2014 That's an interesting anomaly. Only happens on OSX? Must be something in the GDI+ implementation. What was the treatment style chosen for people and did you try any others?
im85288 1493 Posted April 11, 2014 Author Posted April 11, 2014 Yes I think it is OS X only but cannot confirm as I do not have it installed on Windows. I tried all treatment styles for People and the effect is the same. For music with the CD Case everything is fine too. However for Movies/TV shows the results are mixed for Plain, OpenCase, FlatCase and MetroCase things look fine: But for other types such as ClearCase the slice reappears:
ebr 16306 Posted April 11, 2014 Posted April 11, 2014 It is the gloss overlay that is being put on top of those treatments. Something about that OSX doesn't like. 1
Luke 42182 Posted April 11, 2014 Posted April 11, 2014 doesn't like or may very well just not be implemented.
vidkun 10 Posted April 11, 2014 Posted April 11, 2014 What I have found is that when TV shows are scrapped it creates a bunch of metadata and in particular a poster.jpg for the primary image. Initially this is fine, but through the night or whenever the daily schedule runs this primary image get's overwritten with a Banner resulting in the poster.jpg looking like it is suffering from low pixels. To circumvent this I have to go to each TV show and copy/paste the correct poster.jpg to another file called folder.jpg. With the folder.jpg file present the primary image no longer get's overwritten with the incorrect Banner image when the daily update occurs. The same principle applies to Movies too. As discussed in the other thread on the XBMB3C forum, I'm having this same issue running on Windows Server 2012. Copying the correct poster.jpg to a second file named folder.jpg resolves it and prevents the scan job from overwriting the originals. I'm not using CoverArt plugin so I can't comment on that part.
vidkun 10 Posted July 6, 2014 Posted July 6, 2014 im85288: Maybe I missed something, but I thought the poster related image had been resolved. Just realized the other day that I am still having to manually edit the show's images, download the correct "primary" image, then copy the resulting poster.jpg over to folder.jpg. Otherwise, adding new shows results in the primary image being scraped as a banner and showing up looking like crap until the above process is done to fix it. Are you still having that issue as well? I'm pretty sure I'm running the latest stable releases for MB3S and the latest repo version of XBMB3C.
im85288 1493 Posted July 7, 2014 Author Posted July 7, 2014 im85288: Maybe I missed something, but I thought the poster related image had been resolved. Just realized the other day that I am still having to manually edit the show's images, download the correct "primary" image, then copy the resulting poster.jpg over to folder.jpg. Otherwise, adding new shows results in the primary image being scraped as a banner and showing up looking like crap until the above process is done to fix it. Are you still having that issue as well? I'm pretty sure I'm running the latest stable releases for MB3S and the latest repo version of XBMB3C. No, for me and now at least a couple of others: http://mediabrowser.tv/community/index.php?/topic/8454-mb3-constantly-changes-my-primary-images-for-tv-shows-to-banners/ this problem has not been solved. Hopefully @@Luke will be able to reproduce and fix this as it's now being reported by more people
