radioactivesqrl 2 Posted October 3, 2018 Posted October 3, 2018 I just installed version 3.5.2 on FreeNAS which I had to install from scratch, so I'm building up some playlists again. Part way through making playlists, I decided to take a more secure approach and create a separate admin account from my viewing account (which now has no admin rights). I noticed that once I took away admin from my viewing account, I have a more limited list of actions I can perform on my playlists; specifically image and metadata editing are missing. Some functions such as 'subtitles' maybe should require an admin because that would affect global content. As I understand it, the playlists are owned by my viewing account and even the admin doesn't see them when I login under that account. Since my viewer account owns the playlists, it should have full admin rights to modify it. Viewer's menu Viewer(with admin rights)'s Menu I didn't find any other posts about this quirk. Is this intended or a bug?
Luke 42213 Posted October 4, 2018 Posted October 4, 2018 HI, yes this is an issue that needs addressing. Our entire system of playlist management and ownership is something that needs to be reworked. Thanks.
Spaceboy 2573 Posted October 10, 2018 Posted October 10, 2018 You can transfer playlists to other users but not share them
