Jennice 19 Posted October 2, 2018 Posted October 2, 2018 Hi all, Has something changed recently regarding xmltv EPG import? Recently, parts of my EPG info is no longer showing in Emby. /Jennice
Luke 42213 Posted October 2, 2018 Posted October 2, 2018 Nothing has changed. How to report a problem. Thanks.
Carlo 4561 Posted October 2, 2018 Posted October 2, 2018 Hi all, Has something changed recently regarding xmltv EPG import? Recently, parts of my EPG info is no longer showing in Emby. /Jennice What do you find missing?
Jennice 19 Posted October 4, 2018 Author Posted October 4, 2018 (edited) I have issues importing guide data from some channels. I think I have an issue mapping the EPG's channel name to Emby. This causes the guide data not being assigned to a channel. If I understand correctly, Emby uses channel name to assign EPG data.' I am using a HD HomeRun (cable, europe). Is there a way to edit the channel names that Emby uses for the channels? I have not found a wy to edit the names HDHomeRun assigns to a channel (they are given by the provider). Therefore, I think I need a way to edit the names within Emby. Example: Emby calles my ch. 17 as "Discov" (from the tuner, and thus the tv provider). The EPG calls the channel "Discovery Channel". This causes the EPG for channel 17 in Emby to remain empty. Any way to change the names in Emby? EDIT: I found a (in some ways) better provider of EPG for my area, but they provide a link to the full 2 week epg (xx megabyte data), so I need a way to match their naming with Emby. Edited October 4, 2018 by Jennice
EODCrafter 181 Posted October 4, 2018 Posted October 4, 2018 (edited) If I understand correctly, Emby uses channel name to assign EPG data. It may use this but I know for a fact it uses the channel Number from the Guide or channel-id from the m3u. I have a VOD (The Next Friday), which Emby decided to Number as Channel 2 and it links Guide Data for Channel 2 WKRN Nashville to this Channel. I have to create a "fake" xml file and map it to that to get rid of the Mapping...I tried renaming but it still linked. Edited October 4, 2018 by EODCrafter
Jennice 19 Posted October 4, 2018 Author Posted October 4, 2018 HDHomerun does not use m3u list, if I understand Luke (Emby team) correctly.
EODCrafter 181 Posted October 4, 2018 Posted October 4, 2018 (edited) HDHomerun does not use m3u list, if I understand Luke (Emby team) correctly. It does assign Channel Numbers in the Guide...Correct? I gave Both Examples....I edited my example to be more clear.... it uses the channel Number from the Guide or channel-id from the m3u Edited October 4, 2018 by EODCrafter
Jennice 19 Posted October 4, 2018 Author Posted October 4, 2018 The program I currently use to get EPG data (WebGrab++) has a list of entries, for which it fetches data. The the Webgrab++ program, Discovery Channel is ID 70, but it is still linked to Emby Ch 17 (17 used by HD HomeRun). The only thing I BELIEVE they have in common is the name in text. My potential better source for EPG gives me 1 file with ALL the EPG data in it. Therefore I can't assign my own names to the channels in that EPG file. My option would be to either have HDHomeRun tuner channels renamed (opened topic in SiliconDust / HDHomeRun forum), or edit the names Emby adopts from HDHomerun. My question is: Which file contains the channel nummer ~ name info in Emby server? 1
EODCrafter 181 Posted October 4, 2018 Posted October 4, 2018 (edited) The program I currently use to get EPG data (WebGrab++) has a list of entries, for which it fetches data. The the Webgrab++ program, Discovery Channel is ID 70, but it is still linked to Emby Ch 17 (17 used by HD HomeRun). The only thing I BELIEVE they have in common is the name in text. My potential better source for EPG gives me 1 file with ALL the EPG data in it. Therefore I can't assign my own names to the channels in that EPG file. My option would be to either have HDHomeRun tuner channels renamed (opened topic in SiliconDust / HDHomeRun forum), or edit the names Emby adopts from HDHomerun. My question is: Which file contains the channel nummer ~ name info in Emby server? It's not a file, it's a SQ Lite Database...It's not Human-Editable. It would be nice to be able to assign Groups or Channel numbers here, but this is currently in the development stage according to Luke.... Edited October 4, 2018 by EODCrafter
Jennice 19 Posted October 4, 2018 Author Posted October 4, 2018 Not human editable! Damn... I think editing this easily is on my wish list, Luke (in case you're listening)
