Randalllind 0 Posted October 2, 2018 Posted October 2, 2018 (edited) I am new and no matter what I do Emby pauses every 30 sec or so when playing movies. I don't see this issue with TV Shows or when I use chrome with my laptop. If anyone know how to fix this please explan. The movies are mp4. I am using ExoPlayer. I tried VLC but it doesn't seem to play anything and MX Player Pro white circle spins. Edited October 2, 2018 by Randalllind
gnollo 17 Posted October 2, 2018 Posted October 2, 2018 I have not used an external player yet, most people seem to use VLC, which is the best external player to use? Sent from my SM-A520F using Tapatalk
mastrmind11 722 Posted October 2, 2018 Posted October 2, 2018 I am new and no matter what I do Emby pauses every 30 sec or so when playing movies. I don't see this issue with TV Shows or when I use chrome with my laptop. If anyone know how to fix this please explan. The movies are mp4. I am using ExoPlayer. I tried VLC but it doesn't seem to play anything and MX Player Pro white circle spins. well what is the content info? Is it being transcoded? attach the logs.
ebr 16337 Posted October 2, 2018 Posted October 2, 2018 I have not used an external player yet, most people seem to use VLC, which is the best external player to use? None.
ebr 16337 Posted October 2, 2018 Posted October 2, 2018 I am new and no matter what I do Emby pauses every 30 sec or so when playing movies. I don't see this issue with TV Shows or when I use chrome with my laptop. If anyone know how to fix this please explan. The movies are mp4. I am using ExoPlayer. I tried VLC but it doesn't seem to play anything and MX Player Pro white circle spins. Hi. Try lowering the bitrate setting in the app. It just sounds like you are trying to play content that the device or network cannot handle.
Randalllind 0 Posted October 2, 2018 Author Posted October 2, 2018 Hi. Try lowering the bitrate setting in the app. It just sounds like you are trying to play content that the device or network cannot handle. I decided to sideload the android app and uninstall the Fire TV app and no issues. I have no idea why the Fire TV app has issues.
Randalllind 0 Posted October 2, 2018 Author Posted October 2, 2018 well what is the content info? Is it being transcoded? attach the logs. Where do I get the logs?
mastrmind11 722 Posted October 2, 2018 Posted October 2, 2018 (edited) Where do I get the logs? on the server, wherever the logs are being stored. check the dashboard, down toward the bottom it will outline which directories are used for what. Edited October 2, 2018 by mastrmind11
ebr 16337 Posted October 2, 2018 Posted October 2, 2018 Hi. Pinned in most of the forums: How to Report a Problem
Randalllind 0 Posted October 2, 2018 Author Posted October 2, 2018 on the server, wherever the logs are being stored. check the dashboard, down toward the bottom it will outline which directories are used for what. Not my server I have a invite. I will contract the owner
gnollo 17 Posted October 3, 2018 Posted October 3, 2018 None. LOL, why even have an option for an external player then...
Randalllind 0 Posted October 4, 2018 Author Posted October 4, 2018 LOL, why even have an option for an external player then... VLC all it does on my FTV is really fast gives me like a paragraph of text on why it can't play. MX Player works.
Randalllind 0 Posted October 4, 2018 Author Posted October 4, 2018 (edited) I guess Emby wasn't installed right After I removed the FireTV App and sideloaded the Android and it worked. I removed and reinstalled FTV app and all seems to be fine now. Edited October 4, 2018 by Randalllind
ebr 16337 Posted October 4, 2018 Posted October 4, 2018 I guess Emby wasn't installed right After I removed the FireTV App and sideloaded the Android and it worked. I removed and reinstalled FTV app and all seems to be fine now. My guess as to why that would be the case would be due to some option that you changed at some point in the app settings and the uninstall/reinstall set everything back to defaults.
