deecemobile 3 Posted September 29, 2018 Posted September 29, 2018 I am trying to put together a live TV setup to work with Emby. Does anyone have experience that can confirm that HDHomeRun Connect tuner (https://www.silicondust.com/product/hdhomerun-connect/) and Emby Server work well together on Windows 10? I plan to use XML TV for the guide service. Emby can connect to the unit over the network right? Any help appreciated.
deecemobile 3 Posted September 29, 2018 Author Posted September 29, 2018 It works great for me. Good to hear! And you are using https://sourceforge.net/projects/xmltv/ for your guide too?
Sammy 791 Posted October 1, 2018 Posted October 1, 2018 Good to hear! And you are using https://sourceforge.net/projects/xmltv/ for your guide too?I use epg123 but you can load the guide data directly from Schedules Direct in Emby. Schedules Direct costs $25 a year and is well worth it IMHO. Sent from my SM-G930P using Tapatalk
ebr 16337 Posted October 1, 2018 Posted October 1, 2018 Short answer: yes . (assuming your channels are not encrypted) 1
Sammy 791 Posted October 1, 2018 Posted October 1, 2018 Short answer: yes . (assuming your channels are not encrypted) And we thank you! Sent from my SM-G930P using Tapatalk
