pünktchen 1410 Posted September 28, 2018 Posted September 28, 2018 @ would it be possible to create specific collection nodes for every Emby library, similar to unwatched and genre?
pünktchen 1410 Posted September 28, 2018 Author Posted September 28, 2018 It can be done, what is missing for you, what type of library is not being included?In the Kodi Embuary skin every Emby library node has it's own section with tabs for All Movies, Unwatched, Genres and Collections. Unfortunately the collections tab inside the library node shows all collections across all libraries. I only want it to show collections from that specific library. That's why we need some more entry points.
hoppel118 37 Posted September 28, 2018 Posted September 28, 2018 (edited) Hi, I recognized a similar issue, maybe it’s the same. I have libraries for the different video qualities. For example I have the following libraries/nodes: 1. all movies (576p, 1080p and 4K) 2. movies (576p and 1080p) 3. uhd movies (4K only) Now when I open a collection in the library/node „uhd movies“ I also see movies in 576p and 1080p video quality. Is it somehow possible to see only the 4k movies in the collections of the „uhd movies“ library? I use the latest stable versions of Kodi Krypton, Emby Server and EmbyCon. Regards Hoppel Edited September 28, 2018 by hoppel118
hoppel118 37 Posted September 28, 2018 Posted September 28, 2018 (edited) *** double post *** Edited September 28, 2018 by hoppel118
Luke 42240 Posted September 29, 2018 Posted September 29, 2018 The beta server supports that. The stable server will return all collections. 2
hoppel118 37 Posted September 29, 2018 Posted September 29, 2018 The beta server supports that. The stable server will return all collections. Great, thanks for this feature! good to know, I will test with the 3.6 server. At the moment I don’t have the time to test beta server releases. But when 3.6 hits stable I’ll report back here. Regards Hoppel
