Ace11892 0 Posted September 28, 2018 Posted September 28, 2018 (edited) Web version is ok. But the android app doesn't show anything at all. I followed the naming format. I also tried almost every option regarding subtitles. But it isn't working at all. Log file attached... embyserver.txt Edited September 28, 2018 by Ace11892
Luke 42244 Posted September 28, 2018 Posted September 28, 2018 Hi, what device and version of android?
Ace11892 0 Posted September 28, 2018 Author Posted September 28, 2018 Xiaomi redmi note 4x- android 6.0 Sever version- 3.6.0.48 App version-3.0.16
Ace11892 0 Posted September 28, 2018 Author Posted September 28, 2018 One thing to clarify is that I am using the android server to use my android as a storage for server. Recently I updated the server to 3.6.0.49 but it didn't solve my problem. Then downgraded both app and server to see if it solves my problem or not. But no luck! I'm not understanding whether the problem is occurring because of the app or server.
Luke 42244 Posted September 29, 2018 Posted September 29, 2018 @@softworkz, lots of errors starting ffmpeg in this log. 1
Solution softworkz 5133 Posted September 29, 2018 Solution Posted September 29, 2018 @Ace11892: There's a known problem on Marshmallow, it will be fixed in the next or 2nd next version. 1
Ace11892 0 Posted October 2, 2018 Author Posted October 2, 2018 The problem has been solved on new update(3.6.0.51). Extremely thanks to both of you guys for solving it quickly. Regards.
