retrostm 0 Posted September 28, 2018 Posted September 28, 2018 (edited) What happens if I don't allow users to convert media? I'm having sooo many issues adding users and users watching it continiously get in the loading circle.. I restarted the server 3 times in less than 4 hrs. The server is dedicated to emby and is only using less than 30%cpu embyserver.txt Edited September 28, 2018 by retrostm
Luke 42213 Posted September 28, 2018 Posted September 28, 2018 Hi there, can we please discuss an example? Please attach the information requested in how to report a problem. thanks !
retrostm 0 Posted September 28, 2018 Author Posted September 28, 2018 Attached is on my phone but also happened on pc. The server logs are attached in the original post. What is the plurpose of media conversion? What affect will it have if i disable for users?
Luke 42213 Posted September 28, 2018 Posted September 28, 2018 Can you please provide the information I requested above? The Convert feature is a way of converting files. it has nothing to do with browsing and playback. Thanks.
