Scrat 0 Posted October 3, 2018 Author Posted October 3, 2018 See my last posted image. That Hooked folder should show up inside other if I do "ls", right? It doesn't. Sent from my SM-N950W using Tapatalk
MRobi 161 Posted October 3, 2018 Posted October 3, 2018 @@Scrat Hmmm that is definitely an odd one. It may have something to do with mounting in the GUI and as @@makarai suggested each folder may need to be mounted individually if done that way. You seem willing to use shell which is a good thing. Mounting a dataset through the terminal is a very simple command and we know this method works 100% because it's what most of us use. First, unmount everything you've mounted from GUI. Then do this in shell from root (aka before you go into the emby jail using the console command) iocage fstab -a emby "/mnt/databank01/media /media nullfs rw 0 0" 1
Scrat 0 Posted October 3, 2018 Author Posted October 3, 2018 What does that command do? I'll be home around 18h00 CST. FreeBSD 11.2 beta 3 don't let one simply delete a mount point from within a jail, so I'll likely have to redo the Emby jail like the other day. Sent from my SM-N950W using Tapatalk
makarai 109 Posted October 3, 2018 Posted October 3, 2018 (edited) @@Scrat, i am not sure if you understood me correctly or if i might be misunderstanding you. the media folder in the jail itself is fine but instead of linking /mnt/databank01/media/ -> /mnt/iocage/jails/emby-server/root/media please link /mnt/databank01/media/Movies -> /mnt/iocage/jails/emby-server/root/media Alternatively you should log into your jail, go to the rootfolder where you find the /mnt and /media folder and do the following mkdir Movies then you have another folder to mount into exit the jail specific shell and open a freenas shell and type iocage fstab -a emby-server "/mnt/databank01/media/Movies /Movies nullfs rw 0 0" Edited October 3, 2018 by makarai 1
makarai 109 Posted October 3, 2018 Posted October 3, 2018 What does that command do? I'll be home around 18h00 CST. FreeBSD 11.2 beta 3 don't let one simply delete a mount point from within a jail, so I'll likely have to redo the Emby jail like the other day. Sent from my SM-N950W using Tapatalk give this a try: you stop the jail, click on the hamburger symbol click mountpoints and delete the ones you added 1
MRobi 161 Posted October 3, 2018 Posted October 3, 2018 What does that command do? I'll be home around 18h00 CST. FreeBSD 11.2 beta 3 don't let one simply delete a mount point from within a jail, so I'll likely have to redo the Emby jail like the other day. Sent from my SM-N950W using Tapatalk fstab stands for file system table and -a is for 'add'. So what this command does is mount the file system at /mnt/databank/media to whatever directory you choose inside your jail such as /media or /movies, /tv etc.. There's a known bug in the new FreeNAS beta when mounting a file system to a folder that doesn't already exist. The /media folder does exist, but I'm not sure if that bug extends to folders that don't exist inside the media folder (ie: /media/Movies or /Media/Music). Using fstab through shell we know 100% works and will help us eliminate the possible bug as a source of your issue. Follow @@makarai 's steps above and try mounting just your Movies folder and then go into Emby and load those into your library and see what happens. 1
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 (edited) Gotta delete Emby to hopefully get things working. I can't edit a mount point with it creating a new one and not letting me delete the other. Edit 1) Well curse whatever happened.. but Plex sees the 'Movies1' folder I made in terminal under root. Edit 2) Now Emby sees it. Looks like my pet project will be creating folders in shell. Edit 4) @@makarai - Looks like that last snippet of code you gave me to run, made my files invisible in Finder. Found 'em in there over shell. *shakes head* [emoji39] Edited October 4, 2018 by Scrat
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 Well curse whatever happened.. but Plex sees the 'Movies1' folder I made in terminal under root. Sent from my SM-N950W using Tapatalk
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 Now Emby sees it. Looks like my pet project will be creating folders in shell. Hmm.. Sent from my SM-N950W using Tapatalk
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 Umm.. where did my three movies go that I had in there..? Sent from my SM-N950W using Tapatalk
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 At least Emby gets the album art right for movies.. heh Next question, will it read h265 mkv encoded movies? [emoji13] Sent from my SM-N950W using Tapatalk
Luke 42239 Posted October 4, 2018 Posted October 4, 2018 Great job ! And yes, the server supports hevc, but you will need fast enough hardware to transcode it. 1
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 Great job ! And yes, the server supports hevc, but you will need fast enough hardware to transcode it.Server side presumably? Xeon E5-2683-v3 sitting on an ASRock x99 WS-E/10G with 64GB Corsair Dominator memory, Seagate Ironwolf 4TB (x4) attached via hotswap backplane to a mini-sas controller card. There are 2 250GB SSDs attached directly to the board for caching. Overkill? They were cheap.. Crucial MX500 series. $98 CAD/drive. Sent from my SM-N950W using Tapatalk
Luke 42239 Posted October 4, 2018 Posted October 4, 2018 Yes, unless the app you're playing from can direct play hevc.
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 Yes, unless the app you're playing from can direct play hevc.I cheated a touch.. I think. I was playing it through Chrome cause testing. I wanna try the app now on my Note 8. Sent from my SM-N950W using Tapatalk
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 Weird issue: I added movies into the 'Movies1' folder, butt hey aren't seen. The three I added previously are.. but they got moved. /mnt/databank01/media/Movies1 - where the original three wereI log into the Emby console, and go to.. /media/Movies1 - my original three got moved hereWhat gives? I would like the files to stay where I put them so they can be seen by Finder if I wanna modify 'em, or simply see what's in there. Sent from my SM-N950W using Tapatalk
makarai 109 Posted October 4, 2018 Posted October 4, 2018 (edited) Weird issue: I added movies into the 'Movies1' folder, butt hey aren't seen. The three I added previously are.. but they got moved. /mnt/databank01/media/Movies1 - where the original three wereI log into the Emby console, and go to.. /media/Movies1 - my original three got moved hereWhat gives? I would like the files to stay where I put them so they can be seen by Finder if I wanna modify 'em, or simply see what's in there. Sent from my SM-N950W using Tapatalk i am confused, why you say finder what are you exactly talking about? And what do you mean by they moved? nothing should be moving. Emby is like a virtual machine with its own root folder so when you type the command in that i gave you you link the one folder from your nas into the virtual machine from emby, nothing is physically moved. this is your nas location : /mnt/databank01/media/Movies1 this is your emby location /media/Movies1 Edited October 4, 2018 by makarai
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 If nothing should've moved, why are the original three movies not in the folder I put them in? I'm using a Mac.. Finder is like Windows file explorer. Sent from my SM-N950W using Tapatalk
MRobi 161 Posted October 4, 2018 Posted October 4, 2018 If nothing should've moved, why are the original three movies not in the folder I put them in? I'm using a Mac.. Finder is like Windows file explorer. Sent from my SM-N950W using Tapatalk They definitely don't move. Emby runs in a jail, which is it's own little self contained environment. When you mount a folder using the commands, it creates a symbolic link in the area you define. So when you're in your emby jail and go to /media/Movies in the background what's really happening is it's bringing you to /mnt/databank01/media/movies So no files are moved at all
Scrat 0 Posted October 4, 2018 Author Posted October 4, 2018 I know that's how it should work. But why are the three I put in there not listing when I run "ls" or "ls -la" in Terminal when I'm in '/mnt/databank01/media/Movies1'? Sent from my SM-N950W using Tapatalk
MRobi 161 Posted October 4, 2018 Posted October 4, 2018 I know that's how it should work. But why are the three I put in there not listing when I run "ls" or "ls -la" in Terminal when I'm in '/mnt/databank01/media/Movies1'? Sent from my SM-N950W using Tapatalk Do they show if you run it inside the emby jail in /media/Movies1?
Scrat 0 Posted October 5, 2018 Author Posted October 5, 2018 Do they show if you run it inside the emby jail in /media/Movies1?Yes Sent from my SM-N950W using Tapatalk
MRobi 161 Posted October 5, 2018 Posted October 5, 2018 Yes Sent from my SM-N950W using Tapatalk My suspicion is that when you created the Movies1 folder it must have been inside the Emby jail and you unintentionally transferred the files into the jail instead of linking the directory. Only thought I've got if they show inside /media/Movies1 in the jail but not in the main dataset
Scrat 0 Posted October 5, 2018 Author Posted October 5, 2018 Maybe I'll have to wait till RC1 and see if things work better. Honestly, I made the folder in both places. I have yet to transfer files through shell. I did see the command a few days ago, but I don't remember it. Steps in order: Make Movies1 folder in /mnt/databank01/media Make same folder in /media inside Emby jail Ran that command above ending with '..0 0"' Opened Emby, scanned library Sent from my SM-N950W using Tapatalk
