bperun 0 Posted September 27, 2018 Posted September 27, 2018 my server has run for nearly a year no problems as soon as i boot up it hangs and does nothing I CAN install a new version and that runs without a problem but I can not run my instance I have been using, it looks like this cover art plugin is freezing out the system, I never had an issue with it until the start of the week 2018-09-27 17:50:00.518 Info Main: Application path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll2018-09-27 17:50:00.534 Info Main: Emby Command line: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old2018-09-27 17:50:00.874 Info Main: Tray icon path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\electron\embytray2018-09-27 17:50:00.960 Info App: Application version: 3.5.3.02018-09-27 17:50:00.965 Info App: Loading assemblies2018-09-27 17:50:00.999 Info App: File C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\plugins\IMVDb.dll has version 1.0.1.02018-09-27 17:50:01.000 Info App: File C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\plugins\IMVDb.dll has version 1.0.1.02018-09-27 17:50:01.041 Info App: Loading AutoBoxSets, Version=1.1.3.0, Culture=neutral, PublicKeyToken=null from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\plugins\AutoBoxSets.dll2018-09-27 17:50:01.041 Info App: Loading CoverArt, Version=4.0.72.0, Culture=neutral, PublicKeyToken=null from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\plugins\CoverArt.dll2018-09-27 17:50:01.041 Info App: Loading IMVDb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\plugins\IMVDb.dll2018-09-27 17:50:01.041 Info App: Loading MBBackup, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\plugins\MBBackup.dll2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.Plugins.Trailers, Version=1.1.6.0, Culture=neutral, PublicKeyToken=null from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\plugins\Mediabrowser.Plugins.Trailers.dll2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.Api, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.WebDashboard, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.Model, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.Common, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.Controller, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.Providers, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading Emby.Photos, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading Emby.Server.Implementations, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading Emby.Server.MediaEncoding, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading Emby.Dlna, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.LocalMetadata, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading Emby.Notifications, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading Emby.Server.Connect, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.041 Info App: Loading Emby.Server.Sync, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null2018-09-27 17:50:01.204 Info SqliteUserRepository: Sqlite version: 3.24.02018-09-27 17:50:01.204 Info SqliteUserRepository: Sqlite compiler options: COMPILER=msvc-1500,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,MAX_TRIGGER_DEPTH=100,TEMP_STORE=1,THREADSAFE=12018-09-27 17:50:01.242 Info SqliteUserRepository: Default journal_mode for C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\users.db is wal2018-09-27 17:50:01.244 Info SqliteUserRepository: PRAGMA synchronous=12018-09-27 17:50:01.261 Info AuthenticationRepository: Default journal_mode for C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\authentication.db is wal2018-09-27 17:50:01.261 Info AuthenticationRepository: PRAGMA synchronous=12018-09-27 17:50:01.333 Info ActivityRepository: Default journal_mode for C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\activitylog.db is wal2018-09-27 17:50:01.333 Info ActivityRepository: PRAGMA synchronous=12018-09-27 17:50:01.341 Info SqliteDisplayPreferencesRepository: Default journal_mode for C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\displaypreferences.db is wal2018-09-27 17:50:01.341 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=12018-09-27 17:50:01.475 Info SqliteItemRepository: Default journal_mode for C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\library.db is wal2018-09-27 17:50:01.475 Info SqliteItemRepository: PRAGMA synchronous=12018-09-27 17:50:01.672 Info HttpServer: Calling ServiceStack AppHost.Init2018-09-27 17:50:02.143 Info HttpServer: Adding HttpListener prefix http://+:8096/2018-09-27 17:50:02.143 Info HttpServer: Adding HttpListener prefix https://+:8920/2018-09-27 17:50:02.299 Info Skia: SkiaSharp version: 1.60.0.02018-09-27 17:50:02.323 Info TaskManager: Daily trigger for Configuration Backup set to fire at 9/28/2018 12:10:00 AM, which is 379.961281668333 minutes from now.2018-09-27 17:50:02.340 Info TaskManager: Daily trigger for Rotate log file set to fire at 9/28/2018 12:00:00 AM, which is 369.960984301667 minutes from now.2018-09-27 17:50:02.374 Info MediaEncoder: FFMpeg: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\ffmpeg.exe2018-09-27 17:50:02.374 Info MediaEncoder: FFProbe: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\ffprobe.exe2018-09-27 17:50:02.374 Info MediaEncoder: Validating media encoder at C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\ffmpeg.exe2018-09-27 17:50:02.377 Info MediaEncoder: Running C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\ffmpeg.exe -decoders2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: mpeg2video2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: h264_qsv2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: hevc_qsv2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: mpeg2_qsv2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: vc1_qsv2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: h264_cuvid2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: hevc_cuvid2018-09-27 17:50:02.497 Info MediaEncoder: Decoder available: mpeg2_cuvid2018-09-27 17:50:02.498 Info MediaEncoder: Decoder available: mpeg4_cuvid2018-09-27 17:50:02.498 Info MediaEncoder: Decoder available: vc1_cuvid2018-09-27 17:50:02.498 Info MediaEncoder: Decoder available: vp8_cuvid2018-09-27 17:50:02.498 Info MediaEncoder: Decoder available: vp9_cuvid2018-09-27 17:50:02.499 Info MediaEncoder: Decoder available: ac32018-09-27 17:50:02.499 Info MediaEncoder: Decoder available: aac2018-09-27 17:50:02.499 Info MediaEncoder: Decoder available: mp32018-09-27 17:50:02.499 Info MediaEncoder: Decoder available: h2642018-09-27 17:50:02.499 Info MediaEncoder: Decoder available: hevc2018-09-27 17:50:02.501 Info MediaEncoder: Running C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\ffmpeg.exe -encoders2018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: libx2642018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: libx2652018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: mpeg42018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: msmpeg42018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: libvpx2018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: libvpx-vp92018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: aac2018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: libmp3lame2018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: libopus2018-09-27 17:50:02.543 Info MediaEncoder: Encoder available: libvorbis2018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: srt2018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: h264_nvenc2018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: hevc_nvenc2018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: h264_qsv2018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: hevc_qsv2018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: libwebp2018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: ac32018-09-27 17:50:02.544 Info MediaEncoder: Encoder available: h264_amf2018-09-27 17:50:02.545 Info MediaEncoder: Running C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\ffmpeg.exe -protocols2018-09-27 17:50:02.588 Info MediaEncoder: Encoder validation complete2018-09-27 17:50:02.588 Info MediaEncoder: ffmpeg supported protocols: async,bluray,cache,concat,crypto,data,ffrtmpcrypt,ffrtmphttp,file,ftp,gopher,hls,http,httpproxy,https,mmsh,mmst,pipe,rtmp,rtmpe,rtmps,rtmpt,rtmpte,rtmpts,rtp,srtp,subfile,tcp,tls,udp,udplite2018-09-27 17:50:02.589 Info App: ServerId: 533d887bc62e4101b72f1ffc7e87e60d2018-09-27 17:50:02.639 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint2018-09-27 17:50:02.640 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0005011 seconds2018-09-27 17:50:02.640 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint2018-09-27 17:50:02.734 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.0944041 seconds2018-09-27 17:50:02.734 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint2018-09-27 17:50:02.735 Info App: Loading data from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\connect.txt2018-09-27 17:50:02.739 Info App: Loading data from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\wan.dat2018-09-27 17:50:02.857 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.1227511 seconds2018-09-27 17:50:02.857 Info App: Core startup complete2018-09-27 17:50:02.857 Info App: Post-init migrations complete2018-09-27 17:50:02.857 Info App: Starting entry point AutoBoxSets.ServerEntryPoint2018-09-27 17:50:02.873 Info App: Entry point completed: AutoBoxSets.ServerEntryPoint. Duration: 0.0160312 seconds2018-09-27 17:50:02.873 Info App: Starting entry point Emby.Security.PluginSecurityManager2018-09-27 17:50:02.873 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 6.4E-05 seconds2018-09-27 17:50:02.873 Info App: Starting entry point CoverArt.ServerEntryPoint2018-09-27 17:50:02.877 Info CoverArt: CoverArt plugin started with SkiaCoverArtImageProcessor image processor2018-09-27 17:50:02.906 Info App: Entry point completed: CoverArt.ServerEntryPoint. Duration: 0.0328447 seconds2018-09-27 17:50:02.906 Info App: Starting entry point Emby.Security.PluginSecurityManager2018-09-27 17:50:02.906 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 8.02E-05 seconds2018-09-27 17:50:02.906 Info App: Starting entry point MBBackup.ServerEntryPoint2018-09-27 17:50:02.906 Info App: Entry point completed: MBBackup.ServerEntryPoint. Duration: 6.88E-05 seconds2018-09-27 17:50:02.906 Info App: Starting entry point Emby.Security.PluginSecurityManager2018-09-27 17:50:02.906 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 5.14E-05 seconds2018-09-27 17:50:02.906 Info App: Starting entry point MediaBrowser.Plugins.Trailers.EntryPoint2018-09-27 17:50:02.907 Info App: Entry point completed: MediaBrowser.Plugins.Trailers.EntryPoint. Duration: 0.0005502 seconds2018-09-27 17:50:02.907 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint2018-09-27 17:50:02.907 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 8.99E-05 seconds2018-09-27 17:50:02.907 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint2018-09-27 17:50:02.907 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0002809 seconds2018-09-27 17:50:02.907 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint2018-09-27 17:50:02.916 Info App: Loading live tv data from C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\livetv\timers2018-09-27 17:50:03.081 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.1736125 seconds2018-09-27 17:50:03.081 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint2018-09-27 17:50:03.081 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0004838 seconds2018-09-27 17:50:03.081 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup2018-09-27 17:50:03.098 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0167668 seconds2018-09-27 17:50:03.098 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint2018-09-27 17:50:03.099 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0007647 seconds2018-09-27 17:50:03.099 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding2018-09-27 17:50:03.140 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.0405448 seconds2018-09-27 17:50:03.140 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake2018-09-27 17:50:03.140 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0001935 seconds2018-09-27 17:50:03.140 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier2018-09-27 17:50:03.141 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0012494 seconds2018-09-27 17:50:03.141 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier2018-09-27 17:50:03.142 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0010366 seconds2018-09-27 17:50:03.142 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier2018-09-27 17:50:03.145 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.00248 seconds2018-09-27 17:50:03.145 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard2018-09-27 17:50:03.244 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.098917 seconds2018-09-27 17:50:03.244 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents2018-09-27 17:50:03.245 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.000792 seconds2018-09-27 17:50:03.245 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint2018-09-27 17:50:03.247 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.002362 seconds2018-09-27 17:50:03.247 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint2018-09-27 17:50:03.249 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.001966 seconds2018-09-27 17:50:03.249 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier2018-09-27 17:50:03.249 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0003549 seconds2018-09-27 17:50:03.249 Info App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPoint2018-09-27 17:50:03.251 Info App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.0013179 seconds2018-09-27 17:50:03.251 Info App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPoint2018-09-27 17:50:03.252 Info App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.0012662 seconds2018-09-27 17:50:03.252 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint2018-09-27 17:50:03.255 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0035212 seconds2018-09-27 17:50:03.255 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint2018-09-27 17:50:03.256 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0008131 seconds2018-09-27 17:50:03.256 Info App: Starting entry point Emby.Notifications.Notifications2018-09-27 17:50:03.257 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0005445 seconds2018-09-27 17:50:03.257 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint2018-09-27 17:50:03.257 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.0001385 seconds2018-09-27 17:50:03.257 Info App: Starting entry point Emby.Security.PluginSecurityManager2018-09-27 17:50:03.257 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 2.04E-05 seconds2018-09-27 17:50:03.257 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint2018-09-27 17:50:03.261 Info App: Sqlite version: 3.24.02018-09-27 17:50:03.261 Info App: Sqlite compiler options: COMPILER=msvc-1500,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,MAX_TRIGGER_DEPTH=100,TEMP_STORE=1,THREADSAFE=12018-09-27 17:50:03.265 Info App: Default journal_mode for C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\data\sync14.db is wal2018-09-27 17:50:03.266 Info App: PRAGMA synchronous=12018-09-27 17:50:03.269 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0123691 seconds2018-09-27 17:50:03.269 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint2018-09-27 17:50:03.272 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0022968 seconds2018-09-27 17:50:03.272 Info App: All entry points have started2018-09-27 17:50:03.418 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog2018-09-27 17:50:03.750 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=1538085003733. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:03.750 Info HttpServer: HTTP GET http://localhost:8096/web/strings/en-US.json?v=1538085003733. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:03.765 Info HttpServer: HTTP Response 200 to ::1. Time: 17ms. http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-us.json?v=15380850037332018-09-27 17:50:03.765 Info HttpServer: HTTP Response 200 to ::1. Time: 17ms. http://localhost:8096/web/strings/en-US.json?v=15380850037332018-09-27 17:50:03.979 Info HttpServer: HTTP GET http://localhost:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:03.988 Info HttpServer: HTTP Response 200 to ::1. Time: 10ms. http://localhost:8096/emby/system/info/public2018-09-27 17:50:03.991 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.141 Info HttpServer: HTTP Response 200 to ::1. Time: 150ms. http://localhost:8096/emby/System/Info2018-09-27 17:50:04.148 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.149 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.149 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/usersettings?userId=c12d352640744297a4801e1091787d3c&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.153 Info HttpServer: WS http://localhost:8096/embywebsocket?api_key=5842fa125221404c8c9ce67c4179df94&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY0LjAuMzI4Mi4xNDAgU2FmYXJpLzUzNy4zNiBFZGdlLzE3LjE3MTM0fDE1MzgwMTYyNzczMDE1. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.182 Info HttpServer: HTTP Response 200 to ::1. Time: 33ms. http://localhost:8096/emby/DisplayPreferences/usersettings?userId=c12d352640744297a4801e1091787d3c&client=emby2018-09-27 17:50:04.186 Info HttpServer: HTTP Response 200 to ::1. Time: 37ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c2018-09-27 17:50:04.188 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.188 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c2018-09-27 17:50:04.215 Info HttpServer: HTTP Response 204 to ::1. Time: 67ms. http://localhost:8096/emby/Sessions/Capabilities/Full2018-09-27 17:50:04.246 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.251 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.255 Info HttpServer: HTTP Response 304 to ::1. Time: 4ms. http://localhost:8096/web/bower_components/emby-webcomponents/themes/logowhite.png2018-09-27 17:50:04.286 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Views. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.421 Info HttpServer: HTTP Response 200 to ::1. Time: 135ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Views2018-09-27 17:50:04.421 Info HttpServer: HTTP Response 200 to ::1. Time: 175ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Views2018-09-27 17:50:04.447 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=0e3436e0030a3659605f1f4e7052b406. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.447 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=3193d4a5fc822b15a0a6652590e667be. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.447 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=530995f145a46c7249ff93b98e048d4b. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.447 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=117177f103c3c5a3adca602c45a0ae30. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.447 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=b438553face642cfa091e9e43a79f7d4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.447 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.635 Info HttpServer: HTTP Response 200 to ::1. Time: 189ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=0e3436e0030a3659605f1f4e7052b4062018-09-27 17:50:04.636 Info HttpServer: HTTP Response 200 to ::1. Time: 190ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=117177f103c3c5a3adca602c45a0ae302018-09-27 17:50:04.636 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=a4bf15b8887340d5603590ca044f1094. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.636 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6bec15b127c1e3b34c851d6a0e5bc9c0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.653 Info HttpServer: HTTP Response 200 to ::1. Time: 17ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=a4bf15b8887340d5603590ca044f10942018-09-27 17:50:04.658 Info HttpServer: HTTP Response 200 to ::1. Time: 212ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=b438553face642cfa091e9e43a79f7d42018-09-27 17:50:04.660 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=75124c5ffa69d1336ee63e9ddc6e9a91. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.660 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.662 Info HttpServer: HTTP Response 200 to ::1. Time: 217ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=3193d4a5fc822b15a0a6652590e667be2018-09-27 17:50:04.663 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=28b5d5b8bef4bd1f1914503b5c11ac91. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:04.670 Info HttpServer: HTTP Response 200 to ::1. Time: 34ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=6bec15b127c1e3b34c851d6a0e5bc9c02018-09-27 17:50:04.687 Info HttpServer: HTTP Response 200 to ::1. Time: 242ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a8052018-09-27 17:50:04.690 Info HttpServer: HTTP Response 200 to ::1. Time: 244ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=530995f145a46c7249ff93b98e048d4b2018-09-27 17:50:04.707 Info HttpServer: HTTP Response 200 to ::1. Time: 46ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&EnableTotalRecordCount=false&MediaTypes=Video2018-09-27 17:50:04.708 Info HttpServer: HTTP Response 200 to ::1. Time: 48ms. http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=75124c5ffa69d1336ee63e9ddc6e9a912018-09-27 17:50:05.353 Info TaskManager: StartupTrigger fired for task: Check for application updates2018-09-27 17:50:05.355 Info TaskManager: Queueing task SystemUpdateTask2018-09-27 17:50:05.361 Info TaskManager: Executing Check for application updates2018-09-27 17:50:05.370 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases2018-09-27 17:50:06.023 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds2018-09-27 17:50:06.040 Info TaskManager: ExecuteQueuedTasks2018-09-27 17:50:06.164 Info HttpServer: HTTP Response 200 to ::1. Time: 1501ms (slow). http://localhost:8096/emby/Users/c12d352640744297a4801e1091787d3c/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio%2CBasicSyncInfo&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&ParentId=28b5d5b8bef4bd1f1914503b5c11ac912018-09-27 17:50:07.525 Info HttpServer: HTTP GET http://localhost:8096/emby/Sessions?ActiveWithinSeconds=960. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.525 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.525 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.526 Info HttpServer: HTTP GET http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.526 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-09-20T21%3A50%3A07.510Z&hasUserId=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.526 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/System/Info2018-09-27 17:50:07.527 Info HttpServer: HTTP GET http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.529 Info HttpServer: HTTP GET http://localhost:8096/emby/LiveTv/Recordings?UserId=c12d352640744297a4801e1091787d3c&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.534 Info HttpServer: HTTP Response 200 to ::1. Time: 9ms. http://localhost:8096/emby/News/Product?StartIndex=0&Limit=42018-09-27 17:50:07.538 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-09-26T21%3A50%3A07.510Z&hasUserId=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.547 Info HttpServer: HTTP Response 200 to ::1. Time: 18ms. http://localhost:8096/emby/LiveTv/Recordings?UserId=c12d352640744297a4801e1091787d3c&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop2018-09-27 17:50:07.550 Info HttpServer: HTTP Response 200 to ::1. Time: 25ms. http://localhost:8096/emby/Sessions?ActiveWithinSeconds=9602018-09-27 17:50:07.552 Info HttpServer: HTTP Response 200 to ::1. Time: 25ms. http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true2018-09-27 17:50:07.557 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/supporter/supporterbadge.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.559 Info HttpServer: HTTP Response 304 to ::1. Time: 2ms. http://localhost:8096/web/css/images/supporter/supporterbadge.png2018-09-27 17:50:07.564 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.565 Info HttpServer: HTTP Response 200 to ::1. Time: 40ms. http://localhost:8096/emby/ScheduledTasks2018-09-27 17:50:07.583 Info HttpServer: HTTP Response 200 to ::1. Time: 19ms. http://localhost:8096/emby/Packages/Updates?PackageType=System2018-09-27 17:50:07.585 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.590 Info HttpServer: HTTP Response 200 to ::1. Time: 64ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2018-09-20T21%3A50%3A07.510Z&hasUserId=false2018-09-27 17:50:07.590 Info HttpServer: HTTP Response 200 to ::1. Time: 53ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-09-26T21%3A50%3A07.510Z&hasUserId=true2018-09-27 17:50:07.590 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:07.591 Info HttpServer: HTTP Response 304 to ::1. Time: 0ms. http://localhost:8096/web/css/images/logoblack.png2018-09-27 17:50:07.592 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json2018-09-27 17:50:08.156 Info HttpServer: HTTP Response 200 to ::1. Time: 571ms. http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled2018-09-27 17:50:09.338 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/f72ab6b8d55d9d0399cd6a736177483e/Images/Primary?maxHeight=301&maxWidth=187&tag=095d2c7e32d9fe4d593c7153c423a114&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.341 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/bdaac4a325b6dd980b97879f860eb06d/Images/Primary?maxHeight=301&maxWidth=187&tag=76bae21e6a2e1e02b5fa9594b6a1448e&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.342 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/bf368f338110eee9d3442d0165f5d792/Images/Primary?maxHeight=301&maxWidth=187&tag=5cef75a32d7b44589194e8115344a9a3&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.342 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/f5e45090902f98bba2b0a9c4bbbd1c74/Images/Primary?maxHeight=301&maxWidth=187&tag=e002a21434b288e1716b6371ace24bb1&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.348 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/3700f8fc152486ed2127f09bbb14583c/Images/Primary?maxHeight=301&maxWidth=187&tag=d87257e97add99893a1e28b506015aba&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.348 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/153c99256440d0044d9f8cbae8979799/Images/Thumb?maxWidth=299&tag=786026cf128184d3208be15211551923&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.400 Info HttpServer: HTTP Response 200 to ::1. Time: 52ms. http://localhost:8096/emby/Items/153c99256440d0044d9f8cbae8979799/Images/Thumb?maxWidth=299&tag=786026cf128184d3208be15211551923&quality=902018-09-27 17:50:09.401 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/3d15b3082c1407cb164cc8e36fdff2cb/Images/Thumb?maxWidth=299&tag=9b8444547c64f82b8299a7185609d012&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.474 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.5.3.0 Command line: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old System.MissingMethodException: Method not found: 'System.Nullable`1<Boolean> MediaBrowser.Controller.Entities.BaseItem.get_IsHD()'. at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) System.MissingMethodException at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) 2018-09-27 17:50:09.474 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.5.3.0 Command line: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old System.MissingMethodException: Method not found: 'System.Nullable`1<Boolean> MediaBrowser.Controller.Entities.BaseItem.get_IsHD()'. at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) System.MissingMethodException at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) 2018-09-27 17:50:09.475 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.5.3.0 Command line: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old System.MissingMethodException: Method not found: 'System.Nullable`1<Boolean> MediaBrowser.Controller.Entities.BaseItem.get_IsHD()'. at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) System.MissingMethodException at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) 2018-09-27 17:50:09.475 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.5.3.0 Command line: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old System.MissingMethodException: Method not found: 'System.Nullable`1<Boolean> MediaBrowser.Controller.Entities.BaseItem.get_IsHD()'. at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) System.MissingMethodException at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) 2018-09-27 17:50:09.475 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.5.3.0 Command line: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old System.MissingMethodException: Method not found: 'System.Nullable`1<Boolean> MediaBrowser.Controller.Entities.BaseItem.get_IsHD()'. at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) System.MissingMethodException at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) 2018-09-27 17:50:09.489 Info CoverArt: image enhance of Ray Donovan took 0.000 seconds.2018-09-27 17:50:09.497 Info HttpServer: HTTP Response 200 to ::1. Time: 149ms. http://localhost:8096/emby/Items/3700f8fc152486ed2127f09bbb14583c/Images/Primary?maxHeight=301&maxWidth=187&tag=d87257e97add99893a1e28b506015aba&quality=902018-09-27 17:50:09.497 Info HttpServer: HTTP Response 200 to ::1. Time: 155ms. http://localhost:8096/emby/Items/f5e45090902f98bba2b0a9c4bbbd1c74/Images/Primary?maxHeight=301&maxWidth=187&tag=e002a21434b288e1716b6371ace24bb1&quality=902018-09-27 17:50:09.498 Info HttpServer: HTTP Response 200 to ::1. Time: 156ms. http://localhost:8096/emby/Items/bf368f338110eee9d3442d0165f5d792/Images/Primary?maxHeight=301&maxWidth=187&tag=5cef75a32d7b44589194e8115344a9a3&quality=902018-09-27 17:50:09.499 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/1cbde9307c88434514512ba113bf285e/Images/Thumb?maxWidth=299&tag=a4b558b722d9e0d2b7c3e0328d18e2d7&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.499 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/3ea856a646a6b236eb9c2b88cabea3e0/Images/Backdrop?maxWidth=299&tag=9d96c5b5b726e28c94f0aed7d34f0857&quality=70. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.499 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/21906266ea0bc77f3d43c215d047791a/Images/Thumb?maxWidth=299&tag=a60bd3bb3f81228005156370892de80c&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.505 Info HttpServer: HTTP Response 200 to ::1. Time: 6ms. http://localhost:8096/emby/Items/1cbde9307c88434514512ba113bf285e/Images/Thumb?maxWidth=299&tag=a4b558b722d9e0d2b7c3e0328d18e2d7&quality=902018-09-27 17:50:09.505 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/392b31ea2c156fd82f6ca9bfd8e95f99/Images/Thumb?maxWidth=299&tag=0956af16fc833e645fcb01c58dfdf2e4&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.526 Info HttpServer: HTTP Response 200 to ::1. Time: 186ms. http://localhost:8096/emby/Items/bdaac4a325b6dd980b97879f860eb06d/Images/Primary?maxHeight=301&maxWidth=187&tag=76bae21e6a2e1e02b5fa9594b6a1448e&quality=902018-09-27 17:50:09.527 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/aa11927a90ace44d3d0c645e91015c57/Images/Thumb?maxWidth=299&tag=3a096db8b2893ea9378b18ce94c2bd2d&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.533 Info HttpServer: HTTP Response 200 to ::1. Time: 195ms. http://localhost:8096/emby/Items/f72ab6b8d55d9d0399cd6a736177483e/Images/Primary?maxHeight=301&maxWidth=187&tag=095d2c7e32d9fe4d593c7153c423a114&quality=902018-09-27 17:50:09.534 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/4225eeeba4953e3082fe25ad884c0bbd/Images/Primary?maxHeight=301&maxWidth=187&tag=dd23ff9ffe0d8caa7d06a09891e6e535&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.548 Info HttpServer: HTTP Response 200 to ::1. Time: 148ms. http://localhost:8096/emby/Items/3d15b3082c1407cb164cc8e36fdff2cb/Images/Thumb?maxWidth=299&tag=9b8444547c64f82b8299a7185609d012&quality=902018-09-27 17:50:09.549 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/22f33189a449bbe6108d12a1019f251a/Images/Primary?maxHeight=301&maxWidth=187&tag=27cc775205a7fe2a8519c157c6206b8c&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.596 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 3.5.3.0 Command line: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\System.old System.MissingMethodException: Method not found: 'System.Nullable`1<Boolean> MediaBrowser.Controller.Entities.BaseItem.get_IsHD()'. at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) System.MissingMethodException at CoverArt.Skia.CoverArtBaseEnhancer.GetFrameType(BaseItem item, ProfileDefinition profile) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) 2018-09-27 17:50:09.619 Info HttpServer: HTTP Response 200 to ::1. Time: 120ms. http://localhost:8096/emby/Items/3ea856a646a6b236eb9c2b88cabea3e0/Images/Backdrop?maxWidth=299&tag=9d96c5b5b726e28c94f0aed7d34f0857&quality=702018-09-27 17:50:09.619 Info HttpServer: HTTP GET http://localhost:8096/emby/Items/a55f8eef08c5d69d056837af36f912ad/Images/Primary?maxHeight=301&maxWidth=187&tag=9828762a7893fa3acf6cfabbeeec5a45&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/17.17134 2018-09-27 17:50:09.632 Info HttpServer: HTTP Response 200 to ::1. Time: 83ms. http://localhost:8096/emby/Items/22f33189a449bbe6108d12a1019f251a/Images/Primary?maxHeight=301&maxWidth=187&tag=27cc775205a7fe2a8519c157c6206b8c&quality=90
Luke 42213 Posted September 27, 2018 Posted September 27, 2018 Hi, have you tried removing the cover art plugin?
bperun 0 Posted September 27, 2018 Author Posted September 27, 2018 how can i remove it if i can not get to the dashboard ?
bperun 0 Posted September 27, 2018 Author Posted September 27, 2018 could you give me a hint on what do to as far as i know i can only change plugins when i connect via locahost however i can not there are plugins in the programdata folder system folder and system.old folder
Luke 42213 Posted September 28, 2018 Posted September 28, 2018 Try shutting down the server and deleting this file: C:\Users\Wattoz VR\AppData\Roaming\Emby-Server\programdata\plugins\CoverArt.dll Please let us know if this helps. Thanks.
ebr 16310 Posted September 28, 2018 Posted September 28, 2018 The problem is you have a really old version of CoverArt installed. How has it not upgraded?
