pacoyoh 2 Posted September 27, 2018 Posted September 27, 2018 Hello again ! During my tries to resolve my other problem with the playback stop with chromecast, i had an other problem. My server are tiny, so i can't really transcode in real time for big files. So i tried the Emby premiere for the sync/convert and its maybe a solution at this problem. Anyway, i have a strange issue. I can select an entire TV Show (with all seasons), or a single movie, and sync/convert it. But i cant select my entire Movie section, or TV Show (to automatically convert them when i had some news files) to sync/convert. I got an error, but i can't see anything in log. For example, i can convert this Movies, but if i select the entire movies section, i got that. This is normal? Thk in advance !
pacoyoh 2 Posted October 1, 2018 Author Posted October 1, 2018 For information, its a bug of the beta version (already tested with the last beta, already the same). I switched back on stable for now and its ok like that.
Luke 42246 Posted October 1, 2018 Posted October 1, 2018 OK just fyi it is not safe to switch back and forth between the beta and stable, not unless you do a fresh install.
Luke 42246 Posted October 1, 2018 Posted October 1, 2018 Can you try this again on the latest beta server? It would be best to delete existing sync jobs and create new ones. thanks !
pacoyoh 2 Posted October 2, 2018 Author Posted October 2, 2018 Already tested by lasted beta, and already did new tasks. Still the same. And i already switched back to stable on my personal and new server, only my old is still in beta (and going to be deleted anyway), i will let it in beta to test.
