regivaldocosta 2 Posted September 25, 2018 Posted September 25, 2018 (edited) Hi guys, Please, I need a help to install Emby on Samsung MU7000 released in 2107 in Brazil. The procedure cited in thread How to install the official Emby app on a Samsung Smart TV outside the US, UK, and Ireland did'nt work for me because in the remote control does not exist mute key, for example. Please, someone can help me about it? Thanks in advance. Sincerely, Regivaldo Costa Edited September 25, 2018 by regivaldocosta
FrostByte 5453 Posted September 25, 2018 Posted September 25, 2018 If you're using an IR Remote you can use the following 5 key sequence instead >>(FF), 2, 8, 9, <<(REW)
regivaldocosta 2 Posted September 25, 2018 Author Posted September 25, 2018 Hi dear, Thanks for your reply. No, my remote control seems to be radio frenquency. It is exactly like the image in this link: https://zelotek.com/wp-content/uploads/2017/11/mu7000-controle.jpg Cheers! Regivaldo Costa
FrostByte 5453 Posted September 25, 2018 Posted September 25, 2018 Hello, The remote on my 2018 is very similar. On mine Mute is done by pushing in on the button labeled VOL.
regivaldocosta 2 Posted September 26, 2018 Author Posted September 26, 2018 (edited) Hi guys, Everything ok. The tip from FrosByte was a sucess. Now, I have Emby in my UN65MU7000G. Next step, is to evaluation it with Alexa. Thanks a lot. Best regards, Regivaldo Costa Edited September 26, 2018 by regivaldocosta 1
