oceanic 0 Posted September 24, 2018 Posted September 24, 2018 Hello all new user here. My Setup: Proxmox Host Debian 9 LXC Media is on a NAS mounted via NFS Emby 3.5.3.0 Issue playing via DLNA: So this is a weird one for me, i start any video via dlna on my tv (vlc tv app) and it works perfectly fine. However when i try to resume or start the video again it does not work. I can see the following in the logs: 2018-09-24 08:00:45.829 Info HttpServer: HTTP GET http://10.10.5.15:8096/videos/e51001910e949188a4d499c444220859/stream.avi%3FDeviceId=test&MediaSourceId=e51001910e949188a4d499c444220859&Static=true&AudioStreamIndex=1&Tag=6e7f8716586c1160cece775d9c1fc058&dlnaheaders=true. Host=10.10.5.15:8096, User-Agent=VLC/3.0.4 LibVLC/3.0.4, Icy-MetaData=1 2018-09-24 08:00:45.830 Info App: /opt/emby-server/bin/ffmpeg -i file:"/nfs/nas01/10_media/10_movies/10_english/2001 - A Space Odyssey (1968)/2001 - A Space Odyssey (1968).avi" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -vsync -1 -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -y "/var/lib/emby/transcoding-temp/9a36772a308601731ef62a195c04e838.avi?deviceid=test&mediasourceid=e51001910e949188a4d499c444220859&static=true&audiostreamindex=1&tag=6e7f8716586c1160cece775d9c1fc058&dlnaheaders=true" 2018-09-24 08:00:46.082 Error HttpServer: Error processing request *** Error Report *** Version: 3.5.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.18.4 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, EncodingOptions encodingOptions, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.GetStreamResult(StreamState state, IDictionary`2 responseHeaders, Boolean isHeadRequest, CancellationTokenSource cancellationTokenSource) at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.ProcessRequest(StreamRequest request, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IHttpRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) System.Exception at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, EncodingOptions encodingOptions, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.GetStreamResult(StreamState state, IDictionary`2 responseHeaders, Boolean isHeadRequest, CancellationTokenSource cancellationTokenSource) at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.ProcessRequest(StreamRequest request, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IHttpRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) 2018-09-24 08:00:46.082 Info HttpServer: HTTP Response 500 to 10.10.22.1. Time: 253ms. http://10.10.5.15:8096/videos/e51001910e949188a4d499c444220859/stream.avi%3FDeviceId=test&MediaSourceId=e51001910e949188a4d499c444220859&Static=true&AudioStreamIndex=1&Tag=6e7f8716586c1160cece775d9c1fc058&dlnaheaders=true playing the video in the emby app works without a problem.
Luke 42246 Posted September 24, 2018 Posted September 24, 2018 HI, was there an ffmpeg log? can you attach that too? thanks.
oceanic 0 Posted September 24, 2018 Author Posted September 24, 2018 (edited) HI, was there an ffmpeg log? can you attach that too? thanks. Hi Luke, here it is. ffmpeg-directstream-c018282d-a899-4a89-b9e5-4989ab98b066.txt Edited September 24, 2018 by oceanic
Luke 42246 Posted September 25, 2018 Posted September 25, 2018 Ok, I would suggest trying this one again with the next release, thanks.
oceanic 0 Posted September 25, 2018 Author Posted September 25, 2018 Ok, I would suggest trying this one again with the next release, thanks. Thank you i will
