notla49285 48 Posted September 24, 2018 Posted September 24, 2018 Recently (I'd say in the past week), the horizontal scrolling has stopped working when browsing latest stuff on the homepage of my library. Whenever I attempt to scroll left or right it will only go up or down. To access content off to the right I have to pick the program/episode furthest to the right, then go back to the homepage, which has now auto-scrolled to the episode I selected, then keep selecting the right-most episode to get to the one I want, which is very annoying. Any ideas?
notla49285 48 Posted September 24, 2018 Author Posted September 24, 2018 It's the Emby home screen yes, where you have libraries at the top, then Continue Watching, Next Up, Latest Movies, etc. Each of these sections used to be scrollable left/right and now they're not.
Luke 42239 Posted September 24, 2018 Posted September 24, 2018 Hi, would you mind trying this again? I just tested this right now on PS4 and I did not have any problems scrolling in either direction. Thanks.
notla49285 48 Posted September 25, 2018 Author Posted September 25, 2018 Hi Luke, same issue, I've sent a PM with a video of it happening
Luke 42239 Posted September 25, 2018 Posted September 25, 2018 Ok, i saw your video. One of the challenges on ps4 is that you need to use the mouse pointer and selection box via the d-pad in conjunction with each other. Try using the d-pad to navigate and scroll, and then when you want to click on something, then use the mouse pointer to make sure the mouse is on top of it.
notla49285 48 Posted September 26, 2018 Author Posted September 26, 2018 Ok thanks, will try this tonight
notla49285 48 Posted September 27, 2018 Author Posted September 27, 2018 Yeah this works better, cheers Luke
