euromancer 0 Posted September 22, 2018 Posted September 22, 2018 Hi Im having two issues I have just downloaded some videos for my tablet, but when the tablet are offline and i select "My downloads" and i then try to play them using a external player (VLC) then player starts, but exits immediately. So a wanted to change to the internal player, but when i press the settings button then i get the lite with Homescreen, playback and so on, but notinhs happens when i press them, only Camara upload seems to work. If i go online then it works.. And im allso able to play the downloaded videos when usin the internal player.. Im running 3.0.16 PS keep up the good work!
darkassassin07 674 Posted September 22, 2018 Posted September 22, 2018 (edited) You could have your external player monitor the folder emby for android syncs too, then play it directly through the external app forgoing the emby app altogether when offline. Thats what I have been doing with MediaMonkey as my external player. Edited September 22, 2018 by darkassassin07
Luke 42244 Posted September 23, 2018 Posted September 23, 2018 Hi, yes access to app settings in offline mode is something that needs to be looked at. Thanks.
