Terribly slow/long loading on devices using Emby
It's really hard to get the log because it's running over 1MB in size. Rebooting will probably fix the issue, but then the issue will disappear for a while. I've included multiple logs and I hope that they are useful.
I've started with running Emby after enabling the Log file (which took about 2 minutes I think), then tried to change the status of the very first episode of Justified. After 5 minutes of waiting and no update I decided to just upload the log.
Edit: still trying to grab some of the log file of Emby itself, but it's soooooo huge that this might take a while. (Edit edit: don't think it's gonna work, it's practically killing Chrome :P)
Edit 2: after a reboot I get the following message (see photo). Might have something to do with it?
kodi.log
log.txt
log-2018-10-03-12.12.51.zip
Edited by markdj
Angelblue05
I am still looking into this. Thanks for your logs. You do have a lot of updates, but it should not have any effect on opening settings, etc.
And yeah your log is getting big because I said no Kodi debug, lol. It's not needed. Only the add-on debug is needed, which you enable in the add-on settings > advanced.
Angelblue05
I think I finally managed to replicate the issue. At least I hope. Stay tuned.
  • Like 1
Angelblue05
Can you try this build and let me know if the issue persists? I can't seem to make it happen again. Make sure auto-update is disable so the custom build doesn't get overwritten by the beta repo version.
plugin.video.emby-3.1.26b.zip
Just installed it and will check back after work in about 11 hours or so, that should give it enough time to replicate it if it still exists.
  • Like 1
As of right now it seems to work :) Will test further tonight!
  • Like 1
Sorry about that. Have tested it the last few days and the problem seems to be fixed :) Can I set it back to auto-update again now?
Edited by markdj
  • Like 1
Any idea when the fix will be implemented in the new versions?
Angelblue05
Today. Thanks for your patience as I am fixing a few more things.
  • Like 1
  • 2 weeks later...
It seems the issue has returned. While not as long (up to a minute now for playback) it still takes a few seconds after a simple reboot. It happens after the system has been on for a while (>a day).
  • Like 1
highonascii
Can you test something for me that I am testing? In the emby addon settings change playback to only force http and force transcode like in picture above... On my pc things fly open now with pc being on 24/7 and not restarting kodi... I would like to see if this helps people with the "slow down" issue. Thanks
Tried it just now but still slow as ever.
highonascii
Weird... I haven't been able to recreate the slow down since it was fixed but when I tried the above setting it seemed even faster loading... Dang was hoping that would help everyone... Thanks for trying for me none the less :D
To everyone who is facing the slowness issue:
Please check if you have the Skin Helper Script installed and if yes, please disable it temporary and let us know if this solves the issue.
Addons -> Installed addons -> Context menus -> Skin Helper Service
Edited by sualfred
  • Like 1
Says can't be disabled as it's used by embuary skin
Sent from my HTC_M10h using Tapatalk
Hmm I thought disabling works. In that case just delete it manually from your Kodi installation. It can be found in your userdata/addons folder and is called "script.skin.helper.service".
You can reinstall it afterwards via install from repository.
By the way:
I'm currently working on removing this dependency and it won't be required in the future anymore.
Edited by sualfred
  • Like 2
Will give it a try later today. Any reason as to why this might cause the slowdown?
It's gathering additional informations and stuff from fanart.tv/themoviedb/etc. This is expensive and could cause all this troubles.
Just deleted the folder, also didn't have the option to uninstall/disable. Will report later, since it takes a while before the slowdown happens.
  • Like 1
Well, it seems it's also slow to begin with now. But, still not as bad as it was the first time.
highonascii
Testing now
Please also try to remove:
- skin.helper.backgrounds
- script.module.metadatautils (cannot be found in Kodi. Has to be deleted manually)
I've noticed that these two are still doing jobs even without the main skin helper script.
Edited by sualfred
By the way: does this also apply if you're using a different skin?
Yep. These addons are running as service and are active in all skins.
Guest
