fablinuxer 1 Posted September 20, 2018 Posted September 20, 2018 Why Annals Do not Work? I installed the samsung tv app according to the procedure (https://www.youtube.com/watch?v=r6vbwpTj8JM). Only the channels do not work the movies and they would work well. But the channels do not! The word loading ... appears in the upper right corner but the channels do not load!
fablinuxer 1 Posted September 20, 2018 Author Posted September 20, 2018 Hi Dear MODEL:UN40FH5303G TYPE: UN40FH5303
FrostByte 5453 Posted September 20, 2018 Posted September 20, 2018 This is a 2013 hybrid LED TV (FH). Looking at that pic I assume fablinuxer is using the old app or at least loading from zip http://downloadcenter.samsung.com/content/UM/201406/20140616165257575/[ENG]X12ISDBF-1141-0430.pdf 1
fablinuxer 1 Posted September 20, 2018 Author Posted September 20, 2018 I do not know for sure but I believe I have bought between 2013 and 2014.
fablinuxer 1 Posted September 20, 2018 Author Posted September 20, 2018 This is a 2013 hybrid LED TV (FH). Looking at that pic I assume fablinuxer is using the old app or at least loading from zip http://downloadcenter.samsung.com/content/UM/201406/20140616165257575/[ENG]X12ISDBF-1141-0430.pdf Thanks, I'll check it out now!
fablinuxer 1 Posted September 20, 2018 Author Posted September 20, 2018 Thanks, I'll check it out now! Yes it's very similar!
FrostByte 5453 Posted September 20, 2018 Posted September 20, 2018 That was the English user manual for UN40FH5303G, if you need Spanish or another language it's on Samsung's page too. On one of the pages there it says 2013. Not too many hybrid FH models out there As far as your issue with LiveTV channels though I probably won't be of much help
fablinuxer 1 Posted September 20, 2018 Author Posted September 20, 2018 That was the English user manual for UN40FH5303G, if you need Spanish or another language it's on Samsung's page too. On one of the pages there it says 2013. Not too many hybrid FH models out there As far as your issue with LiveTV channels though I probably won't be of much help Movies and series are working fine, only the channels do not load! Is it not supported or did I install the wrong app version!
FrostByte 5453 Posted September 20, 2018 Posted September 20, 2018 Are you using the third party app version 2.2.4? If so, that app unfortunately is no longer in development by the community user who made it and I know LiveTV was just being written when the developer stopped so it may have issues still. If you live outside the US, UK, or Ireland that app is the only one available until the official app is approved by Samsung for world-wide release. Also, I've never really used LiveTV so that may be an area someone else may have to step in with. There are others here who do though
fablinuxer 1 Posted September 20, 2018 Author Posted September 20, 2018 Why Annals Do not Work? I installed the samsung tv app according to the procedure (https://www.youtube.com/watch?v=r6vbwpTj8JM). Only the channels do not work the movies and they would work well. But the channels do not! The word loading ... appears in the upper right corner but the channels do not load! The procedure I used was described above, I do not know how to view the version!
FrostByte 5453 Posted September 20, 2018 Posted September 20, 2018 (edited) When the app first starts there is probably a splash screen and in one of the corners will be the version Edited September 20, 2018 by FrostByte 1
fablinuxer 1 Posted September 21, 2018 Author Posted September 21, 2018 Hi guys, Good Morning, actually the app is 2.2.4. Are there any others that can be installed?
Luke 42241 Posted September 21, 2018 Posted September 21, 2018 Hi, have you checked out our website? This will show you the available apps for your TV: https://emby.media/emby-for-samsung-smart-tv.html Please let us know if this helps. Thanks.
FrostByte 5453 Posted September 21, 2018 Posted September 21, 2018 (edited) What you got then is the latest version of that app before development was stopped. Do you live in the US, UK, or Ireland? If not you may have to wait to see when Samsung approves the official Orsay app for world-wide release and hope they are still approving Orsay apps by then. Unless you want to override the region on your tv and install it now . Edited September 21, 2018 by FrostByte
fablinuxer 1 Posted September 21, 2018 Author Posted September 21, 2018 What you got then is the latest version of that app before development was stopped. Do you live in the US, UK, or Ireland? If not you may have to wait to see when Samsung approves the official Orsay app for world-wide release and hope they are still approving Orsay apps by then. Unless you want to override the region on your tv and install it now . I'm Brasil!"Unless you want to override the region on your tv and install it now" I can do this, I just need to know how? Thanks a lot for the help.
fablinuxer 1 Posted September 21, 2018 Author Posted September 21, 2018 Hi, have you checked out our website? This will show you the available apps for your TV: https://emby.media/emby-for-samsung-smart-tv.html Please let us know if this helps. Thanks. my tv is not on this list Luke!
fablinuxer 1 Posted September 21, 2018 Author Posted September 21, 2018 FrostByte "Unless you want to override the region on your tv and install it now." Do you think this could solve the problem?
FrostByte 5453 Posted September 22, 2018 Posted September 22, 2018 (edited) I really don't know since I don't use LiveTV and not really sure what the issue is. The instructions for changing your TVs region are in the pinned post, but if you do that you lose the ability to use local apps until you set your region back once the app goes world-wide or you decide to just use what you have. Personally I would hold off changing my region for a little while because it sounds like it may be released ww soon. I was hoping that someone who still uses the old app and LiveTV would jump in so we would know if it's an app issue, or some wrong setting somewhere. Edited September 22, 2018 by FrostByte
fablinuxer 1 Posted September 24, 2018 Author Posted September 24, 2018 I really don't know since I don't use LiveTV and not really sure what the issue is. The instructions for changing your TVs region are in the pinned post, but if you do that you lose the ability to use local apps until you set your region back once the app goes world-wide or you decide to just use what you have. Personally I would hold off changing my region for a little while because it sounds like it may be released ww soon. I was hoping that someone who still uses the old app and LiveTV would jump in so we would know if it's an app issue, or some wrong setting somewhere. good night, I think it really is the app, because not even the screen that goes to the channel actually appears.
fablinuxer 1 Posted September 29, 2018 Author Posted September 29, 2018 Good morning friends Certainly this is not the right place, but I have not found the right place. I made the registration on the site to generate EPG (http://www.schedulesdirect.org) I paid and everything seems right, but when configuring in Emby the information does not load, could you help me?
Luke 42241 Posted September 29, 2018 Posted September 29, 2018 HI, try logging into the schedules direct website and preview their lineups for brazil. Make sure they actually have something for your zip code. Please let us know if this helps. Thanks !
