Guest asrequested Posted September 20, 2018 Posted September 20, 2018 (edited) Luke, have you made any tweaks to the UI? Guide on the home screen doesn't work. I just get a black screen. I have to press the home button to get out of that page. To get to the guide, I have to go through Channels or Recordings. Edited September 20, 2018 by Doofus
Luke 42242 Posted September 20, 2018 Posted September 20, 2018 If you restart the app, are you still seeing this?
Guest asrequested Posted September 20, 2018 Posted September 20, 2018 If you restart the app, are you still seeing this? Yes. I restarted, several times. I haven't tried rebooting the machine. But I figure I shouldn't have to.
Luke 42242 Posted September 20, 2018 Posted September 20, 2018 Ok I just pushed a fix. Give it a try again tomorrow. Thanks.
Guest asrequested Posted September 20, 2018 Posted September 20, 2018 Ok I just pushed a fix. Give it a try again tomorrow. Thanks. Thank you. I will let you know
