jimartin 0 Posted September 18, 2018 Posted September 18, 2018 (edited) Hi, I am trying to add some sample sources to test the IPTV plugin but it does not load any of them. It shows loading or black screen and fater that I cant even go back I have to close the tab and repoen Emby web.Example links: rtsp://mm2.pcslab.com/mm/7h800.mp4 http://sample.vodobox.net/skate_phantom_flex_4k/skate_phantom_flex_4k.m3u8 Testing in other applications work also HTTP stream work directly inside a browser. In the logs for m3u8 I see Error 500. Any guidance? embyserver.txt Edited September 18, 2018 by jimartin
Luke 42213 Posted October 10, 2018 Posted October 10, 2018 Hi there, can you also attach the ffmpeg log ?thanks.
