malo87 13 Posted September 17, 2018 Posted September 17, 2018 (edited) I have a problem with my playlists. New songs will no longer be added but the last entry in the file will be replaced all the time. If I check the playlist inside emby I don't see the new songs Furthermore the last line looks different to the others because the path is added Sample: #EXTALB:ZZ Top - Greatest Hits #EXTART:ZZ Top #EXTINF:232,La Grange ZZ Top/ZZ Top - Greatest Hits/ZZ Top -La Grange.flac #EXTALB:ZZ Top - Greatest Hits #EXTART:ZZ Top #EXTINF:134,Tush ZZ Top/ZZ Top - Greatest Hits/ZZ Top -Tush.flac #EXTALB:BÄM #EXTART:Schmutzki #EXTINF:160,Meine Party file:///mnt/nas/music/Schmutzki/BÄM/Schmutzki -Meine Party.mp3/mnt/nas/music/Schmutzki/BÄM/Schmutzki -Meine Party.mp3 The album name contains special characters, so I tried if the error also occurs while adding other songs. Test was fine. Is the problem with "Ä", "Ü", "Ö" know and planed to fix or must I rename everything? Edit: If I add the songs manually to the playlist it's working. Problem only occurs when adding the songs with Emby log20180918.txt Edited September 17, 2018 by malo87
EODCrafter 181 Posted September 17, 2018 Posted September 17, 2018 (edited) I had to rename everything in my TV Section cause my show had ep01 as episode instead of E01 (could not get Emby to resolve these files), @@Luke referenced a similar wiki as this.... https://github.com/MediaBrowser/Wiki/wiki/Music%20naming Edited September 17, 2018 by EODCrafter
Luke 42246 Posted September 18, 2018 Posted September 18, 2018 I had to rename everything in my TV Section cause my show had ep01 as episode instead of E01 (could not get Emby to resolve these files), @@Luke referenced a similar wiki as this.... https://github.com/MediaBrowser/Wiki/wiki/Music%20naming That has no relation here, but thanks.
Luke 42246 Posted September 18, 2018 Posted September 18, 2018 file:///mnt/nas/music/Schmutzki/BÄM/Schmutzki -Meine Party.mp3/mnt/nas/music/Schmutzki/BÄM/Schmutzki -Meine Party.mp3 This will not work because you need to have the same file in your emby library using the exact same path. Do you?
malo87 13 Posted September 18, 2018 Author Posted September 18, 2018 @@EODCrafter Thanks for the information, will try to rename the files if no other solution works. @@Luke The snippet above is what I see in my m3u file after adding the song with emby. Means Emby writes this. Playback of the file with emby is possible without any problems. If I write manually a line containing the exact path to the file it is working. I'm not expert but the line that emby creates contains the path two times doesn't it? Could this be the problem? 1
Luke 42246 Posted September 18, 2018 Posted September 18, 2018 Yes that could be a problem. I'll see if I can reproduce that. Thanks.
malo87 13 Posted September 18, 2018 Author Posted September 18, 2018 (edited) @@Luke Thanks The problem becomes more and more crazy. Like I said before I added some files manually to the playlist and it worked fine but it seems that the media scanner job then removes this files again from the playlist. Mean the files could not be added before to the list by Emby. Playback from the library is still fine... Edited September 18, 2018 by malo87
malo87 13 Posted September 18, 2018 Author Posted September 18, 2018 (edited) One more thing. I added the songs manually by writing a line with its absolute path.Tracks are shown in the playlist and everything was fine.The media scanner (maybe because it happened tonight) transformed everything to multiple lines withEXTARTExtinf...Still one group per track but a different structure than my entry ( /mnt/music/... Mp3 Like you see aboveMaybe here is also a problem Edited September 18, 2018 by malo87
malo87 13 Posted September 19, 2018 Author Posted September 19, 2018 @@Luke I've tried to reproduce my problem using an internal Emby playlist. Using this even the troublemakers are working. For me the problem occurs only when using external m3u files.
