turb1 0 Posted September 17, 2018 Posted September 17, 2018 Hello, I am very satisfied Emby user, everything has been working great till now. I encountered issues with, what I believe is, mono and ssl certificates. I was using lets encrypt certificate successfully for quite a long time, followed instructions from here. Recently I did upgrade from Debian jessie to stretch (9.5) and upgraded all of packages. After that, I am unable to access emby server via https when http works fine. I gathered logs form server (attachment). Can you please point me to some direction, where I should start digging ? I checked certificate and it did not expire but even though I renewed it. Since I am not sure if my emby version (3.5.2.0) relays on mono or not, I tried to add lets encrypt CAs certs to mono trusted certs but no luck. My mono version is 5.14.0.177. logs.txt
Solution Luke 42246 Posted September 17, 2018 Solution Posted September 17, 2018 Hi, please see here: https://emby.media/community/index.php?/topic/59531-external-ssl-connections-crashing/?p=589538 Thanks. 1
turb1 0 Posted September 18, 2018 Author Posted September 18, 2018 Hey, thanks for the reply. I checked certs permissions under /etc/ssl/certs and all of them are symbolic links to certs under /usr/share/ca-certificates/mozilla/ and all of them are readable by any user. Anyway, I readded read permissions for all but the issue is still there.
Luke 42246 Posted September 18, 2018 Posted September 18, 2018 Can you check again? I ask because based on your error message you are the first example I've seen that hasn't been able to resolve this using those instructions. Thanks.
turb1 0 Posted September 18, 2018 Author Posted September 18, 2018 Hey, yup, its working now. I must have done something incorrectly. Appreciate your help
