EODCrafter 181 Posted September 17, 2018 Posted September 17, 2018 (edited) I have refreshed library several times, refreshed Metadata several times and it still won't add info for Season 2. What can I try next? Here is the Folder Structure..... I want it to look like the other Seasons BTW....This is nice.... Edited September 17, 2018 by EODCrafter
Solution Luke 42246 Posted September 17, 2018 Solution Posted September 17, 2018 Hi there, have you compared your file names to our supported naming conventions? https://github.com/MediaBrowser/Wiki/wiki/TV%20naming Please let us know if this helps. Thanks. 1
EODCrafter 181 Posted September 17, 2018 Author Posted September 17, 2018 (edited) Hi there, have you compared your file names to our supported naming conventions? https://github.com/MediaBrowser/Wiki/wiki/TV%20naming Please let us know if this helps. Thanks. So instead of Breaking Bad s02ep01 it should be Breaking Bad S02E01? How is it that the other 4 seasons had no problems finding the info. They are exactly the same? I'll try renaming that season buts that's a pretty lame limitation IMHO. Edited September 17, 2018 by EODCrafter
EODCrafter 181 Posted September 17, 2018 Author Posted September 17, 2018 (edited) That's correct. So why did it add info for the other 4 seasons? It's just random whether it likes the names or not? Perfect...BTW but that's just weird...@@Luke Edited September 17, 2018 by EODCrafter
Luke 42246 Posted September 17, 2018 Posted September 17, 2018 It's impossible to speculate on what might have happened in the past. We need to catch it in the act as it happens. Thanks.
