inforbaix 5 Posted April 9, 2014 Posted April 9, 2014 (edited) Hi, I use Genre Cleaner to map the english definitions of Genres to Spanish definitions. It works great with movies, but when I show my movies grouped by genre all of my movies are grouped in Spanish but appears Genres in english with only Trailers included. Is possible disable the Trailers when view the movies by genres? Thanks. Edited April 9, 2014 by inforbaix
ebr 16344 Posted April 9, 2014 Posted April 9, 2014 Try updating to the beta version I just put up. You may have to manually refresh your trailers to get them to process.
inforbaix 5 Posted April 9, 2014 Author Posted April 9, 2014 Hi, I have version 1.1.0.1 installed and same problem. I uninstalled the trailers plugin, but the trailers still at my library. How can I delete all the trailers of my library?? Manually is very extensive work. Thanks.
ebr 16344 Posted April 9, 2014 Posted April 9, 2014 The beta of GenreCleaner I put up today is 1.0.1.2.
inforbaix 5 Posted April 10, 2014 Author Posted April 10, 2014 Hi, I have deleted manually all the trailers with meta editor, I installed version beta 1.0.2.1 of Genre Cleaner, and now I have the same problem, genres in English that are mapped in plugin configuration but not work in Genre movies selections. Any idea??
ebr 16344 Posted April 11, 2014 Posted April 11, 2014 It is version 1.0.1.2 right? I'm afraid I don't know exactly what is happening here. I will look at it next week.
