rfischman 1 Posted September 16, 2018 Posted September 16, 2018 Using version 1.0.44 of the emby client on this TV. When watching a football game this afternoon on one of the local CBS channels, we could hear the audio from the field, but the commentator audio track was missing. This occurred both when we were playing it directly through the TV and when playing it through the receiver over the 5.1 sound system. When switching to the other local CBS channel in the area, we got the Spanish audio track for the commentators instead of the English one. Server logs are attached Note that audio from the same sources worked just fine using ah Apple TV. Thanks!
rfischman 1 Posted September 16, 2018 Author Posted September 16, 2018 Some follow on info after playing around with the same two CBS channels for 60 minutes (airing currently)... The same type of issues seem to be present where only part of hte audio channel is playing. However, if I manually select the English Dolby 5.1 sound track then it starts playing the appropriate audio immediately. Almost seems like the client side isn't pulling the correct audio track by default in some cases.
FrostByte 5453 Posted September 17, 2018 Posted September 17, 2018 Server logs are attached @@rfischman the logs didn't post for some reason.
rfischman 1 Posted September 17, 2018 Author Posted September 17, 2018 Odd. trying again. good news is this has the log info when I was experimenting the second time and selecting the appropriate audio streams manually to make it work embyserver-63672739200.txt
Luke 42241 Posted September 25, 2018 Posted September 25, 2018 Ok so what you're saying is that live tv on the samsung is choosing an undesirable audio track as the default track. We can look into this, thanks.
