quickmic 1709 Posted September 15, 2018 Author Posted September 15, 2018 I tested on the box as well so an update: First I have to configure the data.json with manual-address but without password and disable password verification on apache proxy. Then start kodi, login etc. So a fresh AccessToken will be generated and saved into data.json. Now I can turn off kodi, add the password in manual-address and enable password verification on apache again and it works. So the point is, the password authentication has a problem with apache password verification, but. btw, I hope I have never to refresh this AccessToken, cause I assume I have to disable apache password again.
Angelblue05 4132 Posted September 15, 2018 Posted September 15, 2018 Yeah you'd have to report your server error which returns 500 trying to generate a token I think.
quickmic 1709 Posted September 15, 2018 Author Posted September 15, 2018 I will do that tomorrow, thx for your help Sometimes it's hard to figure out where the issue actually comes from.
