Guest Normal Posted September 14, 2018 Posted September 14, 2018 When saving a library (that dialog with many options) every option gets saved except the state the top right "Advanced options" checkbox slider thingy.
Luke 42242 Posted September 14, 2018 Posted September 14, 2018 Hi there, can you please discuss an example? Why do you feel they're not saved?
ebr 16335 Posted September 14, 2018 Posted September 14, 2018 I think he just means that every time he goes into that dialog, he has to turn on "Advanced Options" in order to see them.
Guest Normal Posted September 14, 2018 Posted September 14, 2018 Yes, what ebr says is what I mean. This in my opinion feels like an "option" given to the user which state should be saved too.
