BuddahKat 17 Posted September 14, 2018 Posted September 14, 2018 Something happened within the past few days that caused the icons on the Live TV home screen to appear very small. It seems to be isolated to the 'Latest Recording', 'On Now', and 'Shows' categories. I think it must have been a recent update or something because it was displaying perfectly just a couple of days ago. I've attached a screenshot for clarity. I use ServerWMC for my Live TV. It doesn't seem to be affecting the Web version as the 'On Now' category icons are normal size. Maybe it's something with the horizontal view in theater? Just thought I'd report, hopefully its an easy fix.
BuddahKat 17 Posted September 14, 2018 Author Posted September 14, 2018 No I downloaded it from the Emby website...
Luke 42242 Posted September 14, 2018 Posted September 14, 2018 Ok I would give this a try again tonight. Thanks.
BuddahKat 17 Posted September 15, 2018 Author Posted September 15, 2018 I checked today and the icons aren't small anymore but now they aren't wrapping into rows like they used to... I attached another screenshot. Thanks for looking into it!
BuddahKat 17 Posted September 18, 2018 Author Posted September 18, 2018 Seems to be fixed now, thanks!
