BillW 30 Posted April 8, 2014 Posted April 8, 2014 Is there a way to export media browser library information into a spreadsheet? I’m looking to put together and maintain a spreadsheet for my movie/TV collection. The information I want to compile is Name, Year, Season (for TV shows) and Resolution from the library. Then I can add a few fields of my own in the spreadsheet. I want to be able to sort through the movies I want to keep, upgrade the resolution where possible and be able to determine if there are any other related movies I would like to acquire. This isn’t a big deal. It will only take a few evenings to build the spreadsheet manually but if I could automate it using the library database, why not. Thanks
BillW 30 Posted April 8, 2014 Author Posted April 8, 2014 Thanks for the link CBers. I'll go through it tonight when I get home. Work computer blocks a lot of stuff. Geez, and here I thought I had an original idea. Ahh well, should've known better. You folks forgot more about HTPC's than I will ever learn. 1
Koleckai Silvestri 1154 Posted April 8, 2014 Posted April 8, 2014 (edited) I am using JSON calls to the server to pull information. I can then manipulate this to do what I want. Currently using PHP for this. Going to put it in a MySQL database this week. Just need more reporting than is available in the system currently. If you have the server in developer mode, you can use the swagger API to build the links you need. Once you have the JSON result, you can use an online tool to convert it to an Excel file. Just google for JSON to Excel. Edited April 8, 2014 by Wayne Luke
Koleckai Silvestri 1154 Posted April 8, 2014 Posted April 8, 2014 So far my son and I have added television reports for missing episodes by series and missing subtitles by series then episode. For movies the only thing we search for currently is .disc stubs and mp4 stubs less than 2 megabytes.
Luke 42176 Posted April 8, 2014 Posted April 8, 2014 Wayne can you keep us posted on what you add? More features can be added to the core reporting.
Happy2Play 9798 Posted April 8, 2014 Posted April 8, 2014 Since the Server already creates reports (libraryreport.html) is there a way to export those?
Koleckai Silvestri 1154 Posted April 8, 2014 Posted April 8, 2014 Here is some of my very dirty code to pull the data out of MediaBrowser: <?php // Set some variables. $userHash = "UUUUUUUUUUUUUUUUUUUUUU"; $serverURL = "http://XXX.XXX.XXX.XXX:8096/mediabrowser/"; $movieList = "Users/" . $userHash . "/Items?Recursive=true&IncludeItemTypes=Movie&SortBy=SortName"; $latestList = "Users/". $userHash . "/Items?Recursive=true&IncludeItemTypes=Movie&limit=21&SortBy=DateCreated&SortOrder=Descending"; $json_fields ="Budget,Chapters,CriticRatingSummary,DateCreated,Genres,HomePageUrl,IndexOptions,MediaStreams,Overview,OverviewHtml,ParentId,Path,People,ProviderIds,PrimaryImageAspectRatio,Revenue,SortName,Studios,Taglines,TrailerUrl"; $image_path = ".\\images\\movies"; $data_path = ".\\data"; function writeFile($file, $local_path, $newfilename, $getJSON) { $err_msg = ''; $out = fopen($local_path. DIRECTORY_SEPARATOR . $newfilename,"wb"); $ch = curl_init(); curl_setopt($ch, CURLOPT_FILE, $out); curl_setopt($ch, CURLOPT_HEADER, 0); if ($getJSON == true) { curl_setopt($ch, CURLOPT_HTTPHEADER, array('Accept: application/json', 'Content-Type: application/json')); } curl_setopt($ch, CURLOPT_URL, $file); curl_exec($ch); curl_close($ch); } function getMovies($url) { $ch = curl_init(); curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false); curl_setopt($ch, CURLOPT_HTTPHEADER, array('Accept: application/json', 'Content-Type: application/json')); curl_setopt($ch, CURLOPT_RETURNTRANSFER, true); curl_setopt($ch, CURLOPT_URL,$url); $result=curl_exec($ch); return $result; } // Get Movies from MediaBrowser Server. $movies = getMovies($serverURL . $movieList); file_put_contents($data_path. DIRECTORY_SEPARATOR . 'movies.js', $movies); // Get Latest Movies from MediaBrowser Server. $latest = getMovies ($serverURL . $latestList); file_put_contents($data_path. DIRECTORY_SEPARATOR . 'latest.js', $latest); // Parse the Master Movie JSON into an Object Array. $movies = json_decode($movies, true); // Output JSON and Images for each movie. foreach ($movies['Items'] as $movie) { print "Processing " . $movie['Name'] . "(ID:" . $movie['Id'] .").\n"; // Write Individual Movie JSON print "\tWriting JSON...\n"; $movieData = $serverURL . "Items?Ids=" . $movie['Id'] . "&Fields=" . $json_fields; $moviename = $movie['Id'] . "data.js"; writeFile($movieData, $data_path . DIRECTORY_SEPARATOR . 'movies', $moviename, true); // Get and store poster. print "\tWriting poster...\n"; $poster = $serverURL . "Items/" . $movie['Id'] . "/Images/Primary"; $posterfilename= $movie['Id'] . '.poster.jpg'; writeFile($poster, $image_path . DIRECTORY_SEPARATOR . 'posters', $posterfilename, false); // Get and store poster thumbnail print "\tWriting poster thumbnail...\n"; $poster = $serverURL . "Items/" . $movie['Id'] . "/Images/Primary/?Width=134&Height=200"; $posterfilename= $movie['Id'] . '.poster.jpg'; writeFile($poster, $image_path . DIRECTORY_SEPARATOR . 'thumbs', $posterfilename, false); // Get and store Backdrop print "\tWriting backdrop...\n"; $backdrop = $serverURL . "Items/" . $movie['Id'] . "/Images/Backdrop"; $backdropfilename= $movie['Id'] . '.backdrop.jpg'; writeFile($backdrop, $image_path . DIRECTORY_SEPARATOR . 'backdrops', $backdropfilename, false); } ?>
HTPCity_Planner 13 Posted April 9, 2014 Posted April 9, 2014 Great link for JSON: http://www.w3schools.com/json/default.asp
