bertbert72 14 Posted April 8, 2014 Posted April 8, 2014 Run into a problem with the latest build. When I start playing a video to any of my DLNA receivers (Samsung TV, WD TV Live, Popcorn Hour) it starts fine but when I go to remote control it says "Nothing is currently playing". Interesting part, which may or may not be related, is that I run 2 servers. One is where I prep stuff and make sure it looks ok before letting loose on the main server and is running beta build. The main server is set only to run official builds, so hasn't updated yet. It can actually see what is playing from the prep server and allows me to control the device as normal. I've attached the log from the prep server. The play attempt was at 08:05:31.4542. server-63532541074_.log Any ideas what is the problem?
Ghostm 75 Posted April 8, 2014 Posted April 8, 2014 (edited) Same issue. Working in the dev version though so i assume it will be fixed. Edited April 8, 2014 by Ghostm
7illusions 1249 Posted April 8, 2014 Posted April 8, 2014 Yes, we had a parsing error, it is fixed in dev version and will be in the stable release.
swhitmore 781 Posted April 8, 2014 Posted April 8, 2014 Does the ffw/rwd work with the remote? I've only been able to get stop, pause, and volume working on my Samsung.
swhitmore 781 Posted April 8, 2014 Posted April 8, 2014 Test the left/right directional buttons. I'm still on the mines, but I'll be back in a few days. I'll be sure to test all the lovely new features you have added. Thanks for all your hard work on this. 1
bertbert72 14 Posted April 8, 2014 Author Posted April 8, 2014 Thanks for the quick responses. The new release is excellent and the ability to change the DLNA profiles is a life saver. Thanks guys.
