Jrlenz 0 Posted September 12, 2018 Posted September 12, 2018 Hello, I am using Emby to play a slide-show of captured images. The images are changed every 2 minutes by replacing the old one, the image name remains the same. Emby shows the cached image, not the most recent version. Is there a way to force Emby to display the newest image instead of the one it has cached? I don't think the library is being refreshed because the filename doesn't change. Along these lines, is there a way to force Emby to up-size the images. I know it can down-size them, but these images are less than 1920x1080. I can resize them externally, but I would like Emby to do it for me. Thanks for your help, Jeff
Happy2Play 9802 Posted September 12, 2018 Posted September 12, 2018 Hello, I am using Emby to play a slide-show of captured images. The images are changed every 2 minutes by replacing the old one, the image name remains the same. Emby shows the cached image, not the most recent version. Is there a way to force Emby to display the newest image instead of the one it has cached? I don't think the library is being refreshed because the filename doesn't change. Along these lines, is there a way to force Emby to up-size the images. I know it can down-size them, but these images are less than 1920x1080. I can resize them externally, but I would like Emby to do it for me. Thanks for your help, Jeff What OS? Do you have Real time monitoring enabled on that Library? Real time monitoring should see the updates in about 60 seconds assuming your OS supports it.
Luke 42213 Posted September 13, 2018 Posted September 13, 2018 Right, you either need to enable the realtime monitor, or run a library scan.
Jrlenz 0 Posted September 13, 2018 Author Posted September 13, 2018 Thanks for replying so quickly, My server is running on Win7, 64 bit. I double-checked that "Realtime Monitoring" is enabled. I seems that the images will not refresh when the slide-show is running. When I stop the slideshow the images update (within a minute or so). Thanks, Jeff
Luke 42213 Posted September 13, 2018 Posted September 13, 2018 Yes it's true that you may need to restart the slideshow.
