quickmic 1709 Posted September 11, 2018 Posted September 11, 2018 (edited) I wanna report two issues. First, in some cases the cached artwork is damaged. Please check attached photo. On the right edge is a partly green image. This is image corruption, and appears more or less randomly on sync. So if i would rebuild the database, it would appear somewhere else. Only possibility is clearing the artwork-cache to fix the problem. The issue appears on the Vero-box and on desktop, so seems to be a general issue and has nothing to do with performance or network speed. Second problem, in case of renaming a movie or a tvshow, the new item will be integrated in the kodi-db, but the old one will not be removed. Adding new movie or tvshow is correct, I haven't tested just removing so far. thx Edited September 11, 2018 by quickmic
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Your Kodi log please. Your first issue, yes of course. Kodi caches the artwork, the addon only forces Kodi to cache it. So if it's already cached then Kodi won't recache it. You'd need to change the artwork to clear the cached artwork, or as you discovered, clear the artwork cache.
quickmic 1709 Posted September 11, 2018 Author Posted September 11, 2018 (edited) Here we go... I renamed one movie, now I have it two times: "10 to midnight" and "10 to midnight-test" embyserver-movie-rename.txt kodi-movie-rename.log Edited September 11, 2018 by quickmic
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 @@quickmic How can I replicate what you just did? Thank you.
quickmic 1709 Posted September 11, 2018 Author Posted September 11, 2018 I changed the movie-folder name: before: "/mnt/storage2/movies/1/10 To Midnight (1982)/" after: "/mnt/storage2/movies/1/10 To Midnight (1982)-test/" additionally I modifyed the nfo: before: <title>10 to Midnight</title><originaltitle>10 to Midnight</originaltitle> after: <title>10 to Midnight-test</title> <originaltitle>10 to Midnight-test</originaltitle> then on emby server: select "library" select "movie" choose "scan for new and updated files" (don't replace metadata) 1
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Ok, there's a bug in removing movies. Looking into it.
quickmic 1709 Posted September 11, 2018 Author Posted September 11, 2018 Thank you, btw. I think this bug is not just related to movies.
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Are you on emby server 3.6x? If so, looks like there may be a bug and that would explain the issue here: https://emby.media/community/index.php?/topic/62215-36-api-breaking-changes/?p=619373
quickmic 1709 Posted September 11, 2018 Author Posted September 11, 2018 Yes, I am. Thanks for pointing it out.
quickmic 1709 Posted October 12, 2018 Author Posted October 12, 2018 (edited) Sorry to reopen this issue, but It seems the sync-problem is not solved in case of TV-Shows. I run a few tests, and give you an update as soon as possible. At the moment I renamed a complete TV-Show folder (in the directory). c:\bla\Heaven\.... to c:\bla\Haven (2010)\.... Then an emby-server resync, emby-site is now fine. Kodi-Companion Sync results in 2 TV Shows... You can try to reproduce as follows: create: c:\bla\Heaven c:\bla\Heaven\S01\ c:\bla\Heaven\S01\S01E01 - Willkommen in Haven.mkv Scan it on emby-server Scan it on kodi Close kodi rename to c:\bla\Haven (2010)\S01\S01E01 - Willkommen in Haven.mkv Delete all nfo's if you are using them Scan it on emby-server Check emby server, should be fine now. Scan it on kodi -> Duplicate... Edited October 12, 2018 by quickmic
Angelblue05 4132 Posted October 12, 2018 Posted October 12, 2018 Ok I will test this tomorrow. Thanks for the steps to replicate. Will keep you posted as always
quickmic 1709 Posted October 12, 2018 Author Posted October 12, 2018 No problem, take your time. It's not urgent.
