tiger-x 8 Posted September 11, 2018 Posted September 11, 2018 (edited) This morning, Emby for Kodi was updated to 3.1.11a, and there was a problem with the synchronization. Trying to remove the %appdata%\Kodi directory reconfiguration is the same. kodi.log kodi.old.log Edited September 11, 2018 by tiger-x
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Looks like your error wasn't solved after all... Looks like something is up. I'm looking into a possible solution.
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Can you try this? plugin.video.emby-3.1.11a.zip
tiger-x 8 Posted September 11, 2018 Author Posted September 11, 2018 Can you try this? This version can sync all media libraries at the first time, but after re-running Kodi, it will not be synchronized any more. I modified the media library and the modified content will not be synced to Kodi. kodi.log kodi.old.log
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 (edited) Your log looks ok? It updated USERDATA movie [80/80] 5ae2ea5b4a7fff4fff34aa9cbd479c38: 老爸当家 Are you sure, what if you enter the library, does it update visually? Edited September 11, 2018 by Angelblue05
tiger-x 8 Posted September 11, 2018 Author Posted September 11, 2018 Your log looks ok? It updated USERDATA movie [80/80] 5ae2ea5b4a7fff4fff34aa9cbd479c38: 老爸当家 Are you sure, what if you enter the library, does it update visually? 5ae2ea5b4a7fff4fff34aa9cbd479c38 is not the newest movie, will you see the screenshot between browser client and Kodi client, they are different. In the browser client, the newest movie with red frame does not show in kodi. In the kodi client, the newest movie actually is the second new movie. kodi.log
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Can you try this build? Try updating the content in the web client again. plugin.video.emby-3.1.11a.zip
tiger-x 8 Posted September 11, 2018 Author Posted September 11, 2018 Can you try this build? Try updating the content in the web client again. OK, wait a minutes, I am doing with this build.
tiger-x 8 Posted September 11, 2018 Author Posted September 11, 2018 Can you try this build? Try updating the content in the web client again. Hi, this build did not solve the problem, When I re-run Kodi, the program does not perform synchronization. When I click Update Movie in the left menu, nothing happened. Here is the log file. kodi.log
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 How long are you waiting between updating and rerunning Kodi? I can't replicate this issue...
tiger-x 8 Posted September 11, 2018 Author Posted September 11, 2018 How long are you waiting between updating and rerunning Kodi? I can't replicate this issue... I added the movie at 13:36, but the kodi client did not sync that movie now. I reset the kodi local database and re-run kodi, it sync all libraries include that movie.
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Are you talking while Kodi is running or when Kodi is offline, you make the modification, then turn on Kodi and it doesn't sync?
tiger-x 8 Posted September 11, 2018 Author Posted September 11, 2018 Are you talking while Kodi is running or when Kodi is offline, you make the modification, then turn on Kodi and it doesn't sync? Yes! I began to use Emby for Kodi two weeks ago, I remember that is an old version, everytime when I start Kodi, it can sync. and that version didn't need to use Kodi Companion plugins. But this version dosen't sync when Kodi start. 1
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 Ok, I understand what you are saying. No the manual sync does not exist anymore. If you want to get updates without the Kodi companion, you need to run update libraries via launching the add-on and selecting the libraries you want to update. This gives you greater control since the manual sync was pretty awful for large libraries.
Angelblue05 4132 Posted September 11, 2018 Posted September 11, 2018 (edited) Note that I still need to adjust the update behavior to remove content. Right now, to remove content, you have to run a repair library. But to get updates, then updates will do it (you can open the context menu on the library itself via launching the add-on). Edited September 11, 2018 by Angelblue05
tiger-x 8 Posted September 11, 2018 Author Posted September 11, 2018 Note that I still need to adjust the update behavior to remove content. Right now, to remove content, you have to run a repair library. But to get updates, then updates will do it (you can open the context menu on the library itself via launching the add-on). I open the context menu on the library itself via launching the add-on, I click update library, nothing happened, it did not sync new movie. When I click repair library, it began to rescan the library and the new movie is added to kodi. 15:11:19.520 T:1148 NOTICE: EMBY.default -> ---<[ default ] 15:11:28.042 T:3548 NOTICE: EMBY.entrypoint.default -> path: ?mode=synclib&id=f31d6b02b1b7fcc9fa9c88f28f91fc8e params: { "mode": "synclib", "id": "f31d6b02b1b7fcc9fa9c88f28f91fc8e" } 15:11:28.042 T:3548 NOTICE: EMBY.default -> ---<[ default ] 15:11:28.126 T:5920 NOTICE: EMBY.library -> --[ sync/2018-09-11T07:09:28z ] 15:11:28.128 T:5920 NOTICE: EMBY.full_sync -> Full sync completed in: 0:00:00 15:11:28.204 T:672 NOTICE: VideoInfoScanner: Starting scan .. 15:11:28.204 T:672 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00 15:11:28.305 T:9100 WARNING: CGUIMediaWindow::OnMessage - updating in progress 15:11:28.359 T:5920 NOTICE: EMBY.monitor -> -->[ kodi scan/video ] 15:11:28.361 T:5920 NOTICE: EMBY.monitor -> --<[ kodi scan/video ] 15:11:28.420 T:8660 NOTICE: EMBY.entrypoint.default -> path: ?content_type=video params: { "content_type": "video" } 15:11:28.514 T:8660 NOTICE: EMBY.default -> ---<[ default ] 15:11:32.247 T:8112 NOTICE: EMBY.entrypoint.default -> path: ?mode=repairlib&id=f31d6b02b1b7fcc9fa9c88f28f91fc8e params: { "mode": "repairlib", "id": "f31d6b02b1b7fcc9fa9c88f28f91fc8e" } 15:11:32.247 T:8112 NOTICE: EMBY.default -> ---<[ default ] kodi.log
tiger-x 8 Posted September 13, 2018 Author Posted September 13, 2018 Test this build @@highonascii can you try running boxset refresh it and telling me if it makes a difference now? Thank you. @@Seger Your situation is different, access your movies via launching the addon, collections should now show up in the movie listing. Hello, after I use this build, update library can work. But after update library, one of the media libraries has duplicated. If I update library again, duplicated goes double. but it only show in add-on settings context menu, do not show in main screen. kodi first time log.log kodi second time log.log 1
Angelblue05 4132 Posted September 13, 2018 Posted September 13, 2018 @@tiger-x The bug regarding duplicated view should be fixed with the next beta version on the way 3.1.12a
tiger-x 8 Posted September 14, 2018 Author Posted September 14, 2018 @@tiger-x The bug regarding duplicated view should be fixed with the next beta version on the way 3.1.12a The media library can be successfully updated and no duplicates appear in context menu with 3.1.13a. Thanks a lot! 1
