janenner 2 Posted September 9, 2018 Posted September 9, 2018 Hello, Ich installed KODi 18 Leia Beta from scratch and try to use the Emby Plugin 3.1.08a. Connection to the Emby server is established, KODi web server is running and in the Emby Server Companion Plugin ist installed. With this constellation I got "Welcome" message, but the initial library scan don't start. What's to die? kodi.log
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 Did you do a local database reset after updating? It is needed.
sualfred 677 Posted September 9, 2018 Posted September 9, 2018 Did you do a local database reset after updating? It is needed. In case you haven't seen it in his log. 13:50:45.877 T:18446744072804194672 NOTICE: EMBY.entrypoint.service -> Using dynamic paths: True 13:50:45.878 T:18446744072804194672 NOTICE: EMBY.entrypoint.service -> Log Level: 1 13:50:45.900 T:18446744072804194672 NOTICE: Emby.emby.core.configuration -> Begin http constructor. 13:50:45.902 T:18446744072804194672 NOTICE: Emby -> ---[ START EMBYCLIENT ]--- 13:50:45.954 T:18446744072804194672 NOTICE: EMBY.entrypoint.service -> --[ check updates/171076006 ] 13:50:46.111 T:18446744072804194672 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodinerds/files/.kodi/addons/plugin.video.emby/resources/lib/libraries/requests/packages/urllib3/connectionpool.py:791: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.org/en/latest/security.html InsecureRequestWarning) 13:50:46.365 T:18446744072804194672 NOTICE: EMBY.helper.utils -> deleted /storage/emulated/0/Android/data/org.xbmc.kodinerds/files/.kodi/temp/emby 13:50:46.367 T:18446744072804194672 NOTICE: EMBY.downloader -> https://github.com/MediaBrowser/plugin.video.emby/archive/leia.zip 13:50:46.742 T:18446744072804194672 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodinerds/files/.kodi/addons/plugin.video.emby/resources/lib/libraries/requests/packages/urllib3/connectionpool.py:791: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.org/en/latest/security.html InsecureRequestWarning) 13:50:47.700 T:18446744072804194672 ERROR: Previous line repeats 1 times. 13:50:47.700 T:18446744072804194672 NOTICE: EMBY.entrypoint.service -> ERROR:: File is not a zip file Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodinerds/files/.kodi/addons/plugin.video.emby/resources/lib/entrypoint/service.py", line 154, in check_update if get_objects(zipfile, label + '.zip'): # no patch applied previously File "/storage/emulated/0/Android/data/org.xbmc.kodinerds/files/.kodi/addons/plugin.video.emby/resources/lib/downloader.py", line 321, in get_objects with zipfile.ZipFile(path) as zf: File "/var/lib/jenkins/workspace/Android-ARM/default/tools/depends/xbmc-depends/arm-linux-androideabi-21-debug/lib/python2.7/zipfile.py", line 770, in __init__ File "/var/lib/jenkins/workspace/Android-ARM/default/tools/depends/xbmc-depends/arm-linux-androideabi-21-debug/lib/python2.7/zipfile.py", line 811, in _RealGetContents BadZipfile: File is not a zip file 1
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 No I haven't checked the log yet as I'm not at my pc. Thanks 1
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 I am currently looking into this issue, which was also reported here: https://emby.media/community/index.php?/topic/62593-cant-add-or-upate-any-library-on-android/
janenner 2 Posted September 9, 2018 Author Posted September 9, 2018 (edited) OK, thank you! Edited September 9, 2018 by janenner
