mattyg8 18 Posted September 9, 2018 Posted September 9, 2018 I am having an issue today where emby server will not start. I open it and it crashes straight away. I have attached the log files Thanks embyserver-63672120028.txt unhandled_52800a04-91aa-424f-9a2e-f5907a8a41f8.txt
Luke 42213 Posted September 9, 2018 Posted September 9, 2018 Hi, did you go back and forth between beta and stable releases?
mattyg8 18 Posted September 9, 2018 Author Posted September 9, 2018 That may have been the issue. It wouldn't keep installing the update so I tried to manually do it and have probably downloaded the wrong version. Where can I get the latest beta
Solution Luke 42213 Posted September 9, 2018 Solution Posted September 9, 2018 The website. You cannot go back and forth between beta and stable, rather you need to just pick one or the other. Since you started on beta you'll need to stay on it until the 3.6 stable release, at which point you can then switch to stable when the two are the same. Thanks. 1
