sfatula 208 Posted September 9, 2018 Posted September 9, 2018 I have been watch top, and, I see EmbyServer process consuming 35%, but, it is not recording, no schedule tasks are running, there are no clients. The Dashboard shows nothing. It's not causing any issues near as I can tell, still works, but, curious why for 30 minutes now it shows this. Nothing shows up in the log, just the usual DLNA checkups here and there from various devices. Nothing is playing. Machine is otherwise idle. Just curious if this would be normal.
Luke 42246 Posted September 9, 2018 Posted September 9, 2018 Hi there, please attach the emby server log. thanks.
sfatula 208 Posted September 9, 2018 Author Posted September 9, 2018 Sure. But it really doesn't show anything I can find other than occasional checkins. And I am not speaking of a specific time, it's still doing it, has been all day. embyserver.txt
Luke 42246 Posted September 9, 2018 Posted September 9, 2018 I would suggest turning off the server's dlna features, and then restarting the server. See if that helps. Thanks.
sfatula 208 Posted September 10, 2018 Author Posted September 10, 2018 DLNA off, it still happens. Seems to occur after a remote connection, sometimes after a remote connection is done, it goes back to using 30-50%. And that never ends, even a day later.
Luke 42246 Posted September 10, 2018 Posted September 10, 2018 Can you provide a new log from that? thanks.
