TariqK 6 Posted December 21, 2025 Posted December 21, 2025 On 15/04/2019 at 15:42, ebr said: If everything about the two is the same, yes. If, however, the internal one is marked default, then that will have priority. I think this is the issue here, some movie files have the subtitle track marked as default and thus it can give issues. I have problems with some movies having subtitles that cause the movie to fail to play. If its marked as default even when I have external subs then its a problem. It embarrasingly happened once when a movie failed to play when a friend came over until I figured out what it was. Having a setting to ignore all embedded subs per library would eliminate the issue entirely, as I said previousl - Jellyfin has it and people are pretty happy, hope we can have it too
Luke 42243 Posted December 22, 2025 Posted December 22, 2025 9 hours ago, TariqK said: If its marked as default even when I have external subs then its a problem. HI there, can you please provide a specific example? How to Report a Problem Thanks !
