Glyde62 50 Posted September 9, 2018 Author Posted September 9, 2018 Anyone else complaining of this problem? Annoying to have to delete manually Sent from my HTC_M10h using Tapatalk
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 This is alpha/beta. Thanks for your patience while I get to resolving your issue. And no, just you 1
Glyde62 50 Posted September 10, 2018 Author Posted September 10, 2018 Got the update this afternoon now keep getting Emby error on my Nvidia shield when trying to play anything Sent from my HTC_M10h using Tapatalk
Angelblue05 4132 Posted September 10, 2018 Posted September 10, 2018 Restart Kodi or check for updates under the addon settings > advanced.
Glyde62 50 Posted September 10, 2018 Author Posted September 10, 2018 Restart Kodi or check for updates under the addon settings > advanced.Done both numerous times Sent from my HTC_M10h using Tapatalk
Glyde62 50 Posted September 10, 2018 Author Posted September 10, 2018 How do I do that on android Never done it before If I go into media settings in kodi and choose a file it is playing fine Tried re scanning media and uninstalling and reinstalling Emby With no luck Sent from my HTC_M10h using Tapatalk
Angelblue05 4132 Posted September 10, 2018 Posted September 10, 2018 What version of emby for kodi are you running?
Glyde62 50 Posted September 10, 2018 Author Posted September 10, 2018 Latest one showing in kodi 3.1.09a Sent from my HTC_M10h using Tapatalk
Angelblue05 4132 Posted September 10, 2018 Posted September 10, 2018 Are you able to access your kodi folder? https://kodi.wiki/view/Log_file/Advanced#Log_files Or use: https://kodi.wiki/view/Add-on:Kodi_Logfile_Uploader
Glyde62 50 Posted September 10, 2018 Author Posted September 10, 2018 Hope this works https://paste.kodi.tv/exeyilozup 1
Angelblue05 4132 Posted September 10, 2018 Posted September 10, 2018 Thanks, give me a few to fix it for you.
Glyde62 50 Posted September 10, 2018 Author Posted September 10, 2018 Noticed when I checked the shortcuts on my home screen on my shield when I click smart shortcuts then tv shows it doesn't let me choose anything after that On pc lets me choose tv shows, recently added, etc etc Sent from my HTC_M10h using Tapatalk
Angelblue05 4132 Posted September 10, 2018 Posted September 10, 2018 Ok I think I resolved it, Go into the addon settings > advanced > check for updates again. This time it should find a patch and fix your issue. Let me know.
Glyde62 50 Posted September 10, 2018 Author Posted September 10, 2018 Ok I think I resolved it, Go into the addon settings > advanced > check for updates again. This time it should find a patch and fix your issue. Let me know.Seems to have fixed it, was just a quick test as gf is watching The Block on tv (Aussie show) Sent from my HTC_M10h using Tapatalk 1
