abescalamis 88 Posted September 9, 2018 Posted September 9, 2018 (edited) I think you misunderstood what I meant, the things I reported are not related to each other. Issue 1) If you choose to sort by date added, it doesn't work at all, this is a music issue only, for movies it works perfect. Issue 2) artists, albums and songs are not empty, it's just that when I installed 3.1.01, when I would access the music library from inside the add-on, it will display the music like in a folder view and I was able to see the playlist created in emby, I cannot longer access the playlists from emby, only the ones from kodi. Edited September 9, 2018 by abescalamis
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 1- Does it apply to all music types? Albums, Artists and songs? I don't seem to have that issue is why I'm asking. 2- Are you referring to when the music library wasn't synced? Launch the addon as music add-on, then open the context menu on music > Remove library from Kodi. Then access music, is that what you are talking about?
abescalamis 88 Posted September 9, 2018 Posted September 9, 2018 For issue 1, yes, it applies to all, albums, artists and songs, using sorted by date doesn't work. For issue 2, Let me explain this a bit more, 3.1.06 works good, I see the music library in the main window (Home), I can access everything, and everything works (except for the sort by date). But I wanted to access and played my "Emby" music playlist not Kodi playlist, so I went to add-ons--music addons--Emby for Kodi, and when I enter to my music library by doing that, I cannot access the "Emby" music playlist anymore, it's like in the screenshot, if I go down a select playlists it shows me the Kodi playlists. But when I had installed 3.1.01-02, the only issue I had was that it would ask me to scan for tags, and if I would go to add-ons--music addons--Emby for Kodi, I would see my library like in a Folder view, and my Emby music playlist was there.
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 (edited) For issue one, can you confirm your date added in Emby are not identical or some weird scenario? for issue 2, heh, I still don't get it I think. Let me ask you this. You have a playlist provided by Emby. But right now, it's pointing directly to library://music/ when it should be pointing to what? Edited September 9, 2018 by Angelblue05
abescalamis 88 Posted September 9, 2018 Posted September 9, 2018 For issue 1, sorted by date for music has never worked, is just that you mentioned that you will fix it with the update, the order for date added in Kodi is the same as of before you updated the add-on. For issue 2, to make it simple, you wrote in the description of the update that playlists are now supported, it worked with 3.1.01-02, but it doesn't work in 3.1.06 1
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 (edited) Ok yes, I remember now. Fixing issue 1 right now. Thank you for your patience But that's what I don't get see, I haven't changed anything regarding libraries except for audiobooks and books type. Is it maybe under video addons when it should be under music? Edited September 9, 2018 by Angelblue05
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 I am still looking into your issues, 3.1.08 is to fix the progress report issue.
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 @abescalamis Regarding issue 1- I don't think date added is broken. I've checked the database and it's filled correctly. I read up on the database info and it says that date added only refers to the date of the newest song under that album and the newest song under that artist. So date added is fully based on the date of your songs. Please check your songs in the web app > 3 dots > edit metadata. Do they all have the same date? Because that would explain why you think it's never worked...
Home2008 21 Posted September 9, 2018 Posted September 9, 2018 Hi, leider ist mein Englisch schlecht, ich versuche es auf deutsch! Auf Shield TH Update auf 3.1.08a, Kodi dB Reset. Neustart, und in Kodi sind keine Filme TV Shows mehr. Synchronisation ist nicht möglich. 1
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 (edited) @@Home2008 Versuchen Sie es hier https://emby.media/community/index.php?/topic/23971-server-plugin-kodi-companion-fast-sync/?p=618430 Edited September 9, 2018 by Angelblue05
loomes 40 Posted September 9, 2018 Author Posted September 9, 2018 (edited) @@Angelblue05 Found another Bug with strm files. Its only cosmetic, the stream runs fine. P.S. Sorry forget version info: .08a 10:39:45.642 T:176467457264 NOTICE: VideoPlayer::OpenFile: plugin://plugin.video.emby.tvshows/ec8fcdee48fbbd46b2fb02a855124114/?dbid=131&mode=play&id=9ff9653820609efb54cd7c7798cdad2e&filename=s1e2.strm 10:39:45.649 T:177005495536 NOTICE: Creating InputStream 10:39:45.732 T:177005495536 ERROR: AddOnLog: InputStream Adaptive: Key system request: com.widevine.alpha 10:39:45.766 T:176649626864 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.TypeError'> Error Contents: int() argument must be a string or a number, not 'NoneType' Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/player.py", line 87, in onPlayBackStarted self.set_item(current_file, item) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/player.py", line 115, in set_item item['Runtime'] = int(item['Runtime']) TypeError: int() argument must be a string or a number, not 'NoneType' -->End of Python script error report<-- 10:39:45.767 T:176649626864 NOTICE: EMBY.objects.actions -> [ play ] kodi_id: 131 media: episode 10:39:48.666 T:177005495536 NOTICE: Creating Demuxer Edited September 9, 2018 by loomes 1
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 The fix is on github. Tomorrow I'll push the new build out. 1
loomes 40 Posted September 9, 2018 Author Posted September 9, 2018 Thanks, in the meantime i manually edit this.... error in log is gone 1
loomes 40 Posted September 9, 2018 Author Posted September 9, 2018 I have manually add the german translation. There are a Problem in code with german Umlaut "äöü". 11:33:29.031 T:176650265840 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\xfc' in position 1: ordinal not in range(128) Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/service.py", line 44, in <module> session = Service() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/entrypoint/service.py", line 68, in __init__ Views().get_nodes() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 205, in get_nodes self.window_nodes() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 647, in window_nodes self.window_node(index, view, *node) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 700, in window_node window('%s.title' % window_prop, str(node_label) or view['Name']) UnicodeEncodeError: 'ascii' codec can't encode character u'\xfc' in position 1: ordinal not in range(128) -->End of Python script error report<-- When i exchange all "äüö" with "ae" "ue" "oe" the language file works. 1
Angelblue05 4132 Posted September 9, 2018 Posted September 9, 2018 Yes, I will post a fix to address that.
loomes 40 Posted September 10, 2018 Author Posted September 10, 2018 With actual Version, another one, i think is not the last one. 17:21:18.401 T:176649704688 NOTICE: EMBY.database -> ERROR:: type: <type 'exceptions.UnicodeDecodeError'> value: 'ascii' codec can't decode byte 0xc3 in position 1: ordinal not in range(128) 17:21:18.418 T:176649704688 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeDecodeError'> Error Contents: 'ascii' codec can't decode byte 0xc3 in position 1: ordinal not in range(128) Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/service.py", line 44, in <module> session = Service() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/entrypoint/service.py", line 69, in __init__ Views().get_nodes() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 194, in get_nodes self.add_nodes(node_path, view) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 250, in add_nodes self.node(folder, view) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 331, in node self.add_node(NODES[view['Media']].index(node), file, view, xml_name, xml_label) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.emby/resources/lib/views.py", line 376, in add_node write_xml(etree.tostring(xml, 'UTF-8'), file) File "/opt/xbmc-depends/aarch64-linux-android-21-debug/lib/python2.7/xml/etree/ElementTree.py", line 1126, in tostring File "/opt/xbmc-depends/aarch64-linux-android-21-debug/lib/python2.7/xml/etree/ElementTree.py", line 820, in write File "/opt/xbmc-depends/aarch64-linux-android-21-debug/lib/python2.7/xml/etree/ElementTree.py", line 939, in _serialize_xml File "/opt/xbmc-depends/aarch64-linux-android-21-debug/lib/python2.7/xml/etree/ElementTree.py", line 937, in _serialize_xml File "/opt/xbmc-depends/aarch64-linux-android-21-debug/lib/python2.7/xml/etree/ElementTree.py", line 1073, in _escape_cdata UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 1: ordinal not in range(128) -->End of Python script error report<--
