Luke 42255 Posted August 7, 2019 Posted August 7, 2019 @@horstepipe may have some strm file tips. There's a lot of people here using them.
Luke 42255 Posted August 7, 2019 Posted August 7, 2019 Also: https://github.com/MediaBrowser/Wiki/wiki/Strm-files
Shenniko 7 Posted August 29, 2019 Posted August 29, 2019 can you just use rclone to map a drive to your Google Drive, and then point Emby to the newly mapped drive? Thats what im doing to stream my movies from Google Drive..
Disgrace 0 Posted January 19, 2020 Posted January 19, 2020 I have done everything I can think of on how to try to get Emby to see the folder which is mounted to my Gdrive. I followed this: https://github.com/MediaBrowser/Wiki/wiki/Google%20Drive My Gdrive is mounted through Rclone and I can see the Gdrive files through File Manager. So has anyone able to get Emby to see the Mounted Gdrive folder?
Luke 42255 Posted January 20, 2020 Posted January 20, 2020 Hi that's not how the sync feature works. It's used to send files to Google drive, not import them. Not at this time at least.
Wallacebv 0 Posted February 8, 2020 Posted February 8, 2020 @@horstepipe may have some strm file tips. There's a lot of people here using them. oi bom dia sou leigo no assunto mais estou precisando de ajuda pois tenho 5 teras de espaço em meu pc mais esta esgotanto entao quero usar um hd em nuvem ou seja usar filmes e series alocados em nuvem como parte do meu sistema para que o emby possa ter acesso ja tentei e nada alguem pode faser um tutorial pra me ajudar e audar a muitos que provavelmente tenham os mesmos problemas que eu
Luke 42255 Posted February 10, 2020 Posted February 10, 2020 oi bom dia sou leigo no assunto mais estou precisando de ajuda pois tenho 5 teras de espaço em meu pc mais esta esgotanto entao quero usar um hd em nuvem ou seja usar filmes e series alocados em nuvem como parte do meu sistema para que o emby possa ter acesso ja tentei e nada alguem pode faser um tutorial pra me ajudar e audar a muitos que provavelmente tenham os mesmos problemas que eu https://emby.media/community/index.php?/topic/82076-google-drive-strm-emby/?p=842464
