s@m 0 Posted September 7, 2018 Posted September 7, 2018 (edited) ..... Edited September 8, 2018 by s@m
s@m 0 Posted September 7, 2018 Author Posted September 7, 2018 Hi, have you created any sync jobs? please tell me how to create sync jobs???
Luke 42255 Posted September 7, 2018 Posted September 7, 2018 Please check out our wiki on cloud sync and let us know if this helps: https://github.com/MediaBrowser/Wiki/wiki/Google%20Drive Thanks !
s@m 0 Posted September 7, 2018 Author Posted September 7, 2018 (edited) .. Edited September 8, 2018 by s@m
s@m 0 Posted September 7, 2018 Author Posted September 7, 2018 it says No downloads found. Create download jobs using the Download buttons found throughout the app. where is that buttons ???????? plz help
s@m 0 Posted September 7, 2018 Author Posted September 7, 2018 anyone can tell me where is the suction that in the pic ??? or where the Download buttons ?
s@m 0 Posted September 7, 2018 Author Posted September 7, 2018 never mind i will stay with plex and deleting emby thank you for nothing ^^
Luke 42255 Posted September 8, 2018 Posted September 8, 2018 Sorry, it has been changed to Sync. So instead of right click -> download, it's right click -> sync.
s@m 0 Posted September 8, 2018 Author Posted September 8, 2018 (edited) .- Edited September 8, 2018 by s@m
Luke 42255 Posted September 8, 2018 Posted September 8, 2018 I think you are misunderstanding what this feature is. It is a sync, to send content to google drive from your emby server, not the other way around. So first you need to add a media library to Emby Server. Then once you've done that, then you can right click on a media poster and sync it to google drive. 2
s@m 0 Posted September 8, 2018 Author Posted September 8, 2018 I think you are misunderstanding what this feature is. It is a sync, to send content to google drive from your emby server, not the other way around. So first you need to add a media library to Emby Server. Then once you've done that, then you can right click on a media poster and sync it to google drive. omg so its not like plex google drive its streaming from your google drive ? so on emby there is no streaming from cloud ?????????????????????????
s@m 0 Posted September 8, 2018 Author Posted September 8, 2018 i Subscribed to emby premiere bcuz i want to stream from my google drive account not send to my google drive !!!! omg guys why you dont write this in your web site !!! so my subscribe its for nothing and i paid for nothing !!! can i get back my money ???
ebr 16346 Posted September 8, 2018 Posted September 8, 2018 Hi. The website does describe the feature as "Cloud Sync". Once the content is synced, then apps that can best utilize the cloud content will stream from there. Does that not satisfy what you need?
damien990 0 Posted October 9, 2018 Posted October 9, 2018 (edited) I think you are misunderstanding what this feature is. It is a sync, to send content to google drive from your emby server, not the other way around. So first you need to add a media library to Emby Server. Then once you've done that, then you can right click on a media poster and sync it to google drive. Hi Luke Thanks you! I got the answer finally clear now. So If I want to sync the whole library to Google Drive, which way is easier and faster? Is that this will solve the playback slow transcoding issue? Damien Edited October 9, 2018 by damien990
Luke 42255 Posted October 9, 2018 Posted October 9, 2018 You can do it from a top level folder if you want. 1
Ckandres 0 Posted October 18, 2018 Posted October 18, 2018 I had the same problem i just paid the service because i though i can get my google drive contend and checking on emby, what a wast of money...
damien990 0 Posted October 18, 2018 Posted October 18, 2018 I had the same problem i just paid the service because i though i can get my google drive contend and checking on emby, what a wast of money... Dont worry! you have to right click "sync" on your video in order to create the sync process to GDrive. a new Emby version 3.6 can resolve cloud sync playback issue online. So just expect the new version.
erikblues 4 Posted January 17, 2019 Posted January 17, 2019 I think you are misunderstanding what this feature is. It is a sync, to send content to google drive from your emby server, not the other way around. So first you need to add a media library to Emby Server. Then once you've done that, then you can right click on a media poster and sync it to google drive. Hi @@Luke , A few questions about how this works: I am looking at enabling a full sync of my local library with google drive using the synology app, to have a full backup of my NAS on google drive. Is there a way to use those files or do I have to make emby sync them to google drive? I want to use the local files on the NAS when streaming at home (same LAN) and use google drive when I'm outside and/or need a different resolution. But It is not clear to me how this would work exactly. For example: If I'm traveling and need to stream a movie, will it always use google drive or only when a different resolution is used? Will transcoding happen in the Emby server or will it use Google's "change format" feature? This guide I found explains how to set things up, but it doesn't answer the questions above. Do you mind giving me some more info about this?
Luke 42255 Posted January 18, 2019 Posted January 18, 2019 Try syncing some movies and tv shows, basically a few of each content type that you need. Once you learn the synced folder structure, you might be able to copy existing files in there. Keep in mind we haven't tested this. I want to use the local files on the NAS when streaming at home (same LAN) and use google drive when I'm outside and/or need a different resolution. But It is not clear to me how this would work exactly. For example: If I'm traveling and need to stream a movie, will it always use google drive or only when a different resolution is used? If the client app can direct play the google drive version, based on supported formats as well as all quality settings, then it will pick that version by default. You can choose the version you want to play on the detail screen. Will transcoding happen in the Emby server or will it use Google's "change format" feature? Within Emby. 1
gtmnyc 12 Posted April 1, 2019 Posted April 1, 2019 right in plain language can we play videos from gdrive
Luke 42255 Posted April 1, 2019 Posted April 1, 2019 Not natively, but there are techniques such as .strm files that you can use to accomplish this.
gtmnyc 12 Posted April 1, 2019 Posted April 1, 2019 Not natively, but there are techniques such as .strm files that you can use to accomplish this. i can scrape gdrive into strm but we cant map a drive
euclides.sp 6 Posted August 7, 2019 Posted August 7, 2019 Not natively, but there are techniques such as .strm files that you can use to accomplish this. I read about it last week. I have here emby installed on a vps using rclone to connect with my gdrive. Someone available to help me with these .strm files
