Embyebye 0 Posted September 7, 2018 Posted September 7, 2018 Windows 10 App: there is a option 'wake up' Android Smartphone: there is also an option 'wake up' Android TV app....euhh..no forced option to trigger the 'wake up' ???? Maybe it's triggerd when you push the server button (ugly server icon), but it's not working. I saw a post from 2016 here, it should be a Androin thing...but...it's working on my Android Smartphone! request 1: please add option 'wake up' in the Emby Android TV app request 2: please fix 'wake up', without this feature working I am not happy request 3: I have only 1 server.........why do you not send the WOL when I start Emby first??? and why I have to select a server.... I only have 1 server!! Could you make my live make simpler? thank you all ready ! Kind regards (Emby starter)
Luke 42245 Posted September 7, 2018 Posted September 7, 2018 Hi, we haven't yet added this feature to the Android TV app, but it's planned for the future. Thanks.
Luke 42245 Posted September 7, 2018 Posted September 7, 2018 request 3: I have only 1 server.........why do you not send the WOL when I start Emby first??? and why I have to select a server.... I only have 1 server!! Could you make my live make simpler? have you explored the auto-login settings in the app?
Embyebye 0 Posted September 7, 2018 Author Posted September 7, 2018 Next week = future right? And can't be difficult anymore......you know how to implement in Android Smartphone......now re-use the code on Android TV Yes I use Auto-login...I forgot. But when the server is offline....of course I have to select te server. So forget about request #3 Hope to see a new Android TV release very soon !
foobar99 0 Posted January 31, 2019 Posted January 31, 2019 There's a WOL app right here: https://play.google.com/store/apps/details?id=com.gbsoft.wol, Works perfectly on android TV. You can wake multiple devices from your android tv device. It even shows devices in a channel on your home screen. Very happy with it.
Luke 42245 Posted February 1, 2019 Posted February 1, 2019 The Emby Android TV app has this feature now.
