tctfox 0 Posted September 7, 2018 Posted September 7, 2018 Hei I have a problem If i check a series as marked (like s1 from westworld) on my home screen it isnt showing me s2 or the next episode. In plex it works flawlesly what could be the problem? Also if I mark 50 episodes as watched it isnt showing the 51th episode on my home screen. I checked the continue watching box in tje settings so yes I dont get why. Thx guys
ebr 16310 Posted September 7, 2018 Posted September 7, 2018 Hi. Have you actually played an episode from ether of those series?
tctfox 0 Posted September 7, 2018 Author Posted September 7, 2018 I marked them as watched, because I watched them on plex and switched to emby
ebr 16310 Posted September 7, 2018 Posted September 7, 2018 Okay, so our next up will only show series you have actually started watching. If you just play an episode from those series for a few seconds, then they will be in the next up queue and stay there even if you manually mark items after that.
tctfox 0 Posted September 7, 2018 Author Posted September 7, 2018 So next up and continue watching , are only showing the episodes i startet watching and not the next one if I finished one?
Luke 42213 Posted September 7, 2018 Posted September 7, 2018 Continue watching is for resumable media. Next up will show you the next one to watch. Please let us know if this helps. Thanks.
tctfox 0 Posted September 7, 2018 Author Posted September 7, 2018 It worked now, dont know why but good for now! Thx for helping
tctfox 0 Posted September 7, 2018 Author Posted September 7, 2018 Now the next up is not there again. So strange
Luke 42213 Posted September 7, 2018 Posted September 7, 2018 Can you please discuss an example? Thanks.
