tdiguy 99 Posted September 6, 2018 Posted September 6, 2018 I thought this was due to a drive power / standby setting. However it persists after i have turned spin down off and standby off. It sometimes takes quite a while to start playing the desired movie. I am not sure if it is a client side issue or a server side issue. The clients is a mi box 3 running emby 1.6.15 the server is running 3.5.2.0 the server is ubuntu 16.04.5 normally it has very little load even running emby. Aside from system services it runs webmin and emby. Ram is normally only 30-40% utilized and swap is normally not used.
Luke 42246 Posted September 6, 2018 Posted September 6, 2018 Hi there, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
tdiguy 99 Posted September 6, 2018 Author Posted September 6, 2018 Ok, there was no error message, just took a long time to load and a few attempts to play. This is the server log. It was for Mickey_Donald_Goofey at about 4:30pm I believe. server.txt
