Luke 42213 Posted September 17, 2018 Posted September 17, 2018 hi @@Vito_MCE, please attach the emby server log. thanks !
dravokivich 3 Posted September 17, 2018 Author Posted September 17, 2018 I went for the nuclear option last night. Completely uninstalled emby. Installed beta. No stability issues coming up yet.
dravokivich 3 Posted September 17, 2018 Author Posted September 17, 2018 It seems my eagerness to suggest this is sorted... was a bit eager. As soon as I went to watch something just now. The same issues came up again.
Vito_MCE 1 Posted October 13, 2018 Posted October 13, 2018 I was able to eliminate the issue with Anime movies completely by renaming one folder from "Ranma ½" to just "Ranma". Looks like emby does not like filenames with Unicode fractions in it. I have not seen any crashes since then. I guess it it may be worth a look. Interesting that I have no issues with national characters which I use a lot.
Luke 42213 Posted October 13, 2018 Posted October 13, 2018 Thanks for the feedback. This should be resolved for the next release of the server.
Vito_MCE 1 Posted October 15, 2018 Posted October 15, 2018 I have also narrowed down the issue with crashing on Vikings due to Alex Høgh Andersen. I bet "ø" is causing this. Removing actor solves the issue. Glad to read you have found the resolution.
Happy2Play 9803 Posted October 15, 2018 Posted October 15, 2018 I have also narrowed down the issue with crashing on Vikings due to Alex Høgh Andersen. I bet "ø" is causing this. Removing actor solves the issue. Glad to read you have found the resolution. Is this a server language or OS issue? As I have this actor with original spelling on English Windows server without issue.
Luke 42213 Posted October 15, 2018 Posted October 15, 2018 It is resolved for emby server 3.6. thanks.
