alucryd 318 Posted November 28, 2018 Posted November 28, 2018 We're not using the ImageMagick binaries from your system, we're directly using the MagickWand library via C# bindings. A such, we're shipping our own library in the package. This library is correctly detected on my FreeBSD VM, but maybe I missed some dependency in the package we're publishing. Could you please run the following on your system? cd /usr/local/lib/emby-server/lib export LD_LIBRARY_PATH=$(pwd) ldd libMagickWand-6.Q8.so.6.0.0 You'll get something like this: libMagickWand-6.Q8.so.6.0.0: libMagickCore-6.Q8.so.6 => /usr/local/lib/emby-server/lib/libMagickCore-6.Q8.so.6 (0x801400000) libtiff.so.5 => /usr/local/lib/libtiff.so.5 (0x80195e000) libjpeg.so.8 => /usr/local/lib/libjpeg.so.8 (0x801bd8000) libpng16.so.16 => /usr/local/lib/libpng16.so.16 (0x801e6b000) libfontconfig.so.1 => /usr/local/lib/libfontconfig.so.1 (0x8020a6000) libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x8022ed000) libwebpmux.so.3 => /usr/local/lib/libwebpmux.so.3 (0x8025a3000) libwebp.so.7 => /usr/local/lib/libwebp.so.7 (0x8027ad000) libraw_r.so.16 => /usr/local/lib/libraw_r.so.16 (0x802a3c000) liblcms2.so.2 => /usr/local/lib/liblcms2.so.2 (0x802d38000) libz.so.6 => /lib/libz.so.6 (0x802f94000) libgomp.so.1 => /usr/local/lib/gcc6/libgomp.so.1 (0x8031ac000) libm.so.5 => /lib/libm.so.5 (0x8033d8000) libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x803605000) libthr.so.3 => /lib/libthr.so.3 (0x803814000) libc.so.7 => /lib/libc.so.7 (0x800823000) liblzma.so.5 => /usr/lib/liblzma.so.5 (0x803a3c000) libjbig.so.2 => /usr/local/lib/libjbig.so.2 (0x803c65000) libexpat.so.1 => /usr/local/lib/libexpat.so.1 (0x803e72000) libbz2.so.4 => /usr/lib/libbz2.so.4 (0x80409c000) libc++.so.1 => /usr/lib/libc++.so.1 (0x8042b0000) libcxxrt.so.1 => /lib/libcxxrt.so.1 (0x80457e000) libdl.so.1 => /usr/lib/libdl.so.1 (0x80479d000) If something is "not found" that will be the issue. Quick question, are you on the latest or quarterly release cycle? Our packages are based on latest.
marcelolagos 1 Posted November 29, 2018 Author Posted November 29, 2018 No missing dependencies that I can see. root@emby:/usr/local/lib/emby-server/lib # cd /usr/local/lib/emby-server/lib/ root@emby:/usr/local/lib/emby-server/lib # setenv LD_LIBRARY_PATH /usr/local/lib/emby-server/lib root@emby:/usr/local/lib/emby-server/lib # ldd libMagickWand-6.Q8.so.6.0.0 libMagickWand-6.Q8.so.6.0.0: libMagickCore-6.Q8.so.6 => /usr/local/lib/emby-server/lib/libMagickCore-6.Q8.so.6 (0x801400000) libtiff.so.5 => /usr/local/lib/libtiff.so.5 (0x80195e000) libjpeg.so.8 => /usr/local/lib/libjpeg.so.8 (0x801bd8000) libpng16.so.16 => /usr/local/lib/libpng16.so.16 (0x801e47000) libfontconfig.so.1 => /usr/local/lib/libfontconfig.so.1 (0x802082000) libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x8022c9000) libwebpmux.so.3 => /usr/local/lib/libwebpmux.so.3 (0x80257f000) libwebp.so.7 => /usr/local/lib/libwebp.so.7 (0x802789000) libraw_r.so.16 => /usr/local/lib/libraw_r.so.16 (0x802a18000) liblcms2.so.2 => /usr/local/lib/liblcms2.so.2 (0x802d14000) libz.so.6 => /lib/libz.so.6 (0x802f70000) libgomp.so.1 => /usr/local/lib/compat/libgomp.so.1 (0x803188000) libm.so.5 => /lib/libm.so.5 (0x803390000) libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x8035bd000) libthr.so.3 => /lib/libthr.so.3 (0x8037cc000) libc.so.7 => /lib/libc.so.7 (0x800823000) liblzma.so.5 => /usr/lib/liblzma.so.5 (0x8039f4000) libjbig.so.2 => /usr/local/lib/libjbig.so.2 (0x803c1d000) libexpat.so.1 => /usr/local/lib/libexpat.so.1 (0x803e2a000) libbz2.so.4 => /usr/lib/libbz2.so.4 (0x804054000) libc++.so.1 => /usr/lib/libc++.so.1 (0x804268000) libcxxrt.so.1 => /lib/libcxxrt.so.1 (0x804536000) root@emby:/usr/local/lib/emby-server/lib # I had to use setenv as I don't have export. And using the default: quarterly. root@emby:/usr/local/lib/emby-server/lib # cat /etc/pkg/FreeBSD.conf # $FreeBSD: releng/11.2/etc/pkg/FreeBSD.conf 333474 2018-05-10 23:58:33Z gjb $ # # To disable this repository, instead of modifying or removing this file, # create a /usr/local/etc/pkg/repos/FreeBSD.conf file: # # mkdir -p /usr/local/etc/pkg/repos # echo "FreeBSD: { enabled: no }" > /usr/local/etc/pkg/repos/FreeBSD.conf # FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/quarterly", mirror_type: "srv", signature_type: "fingerprints", fingerprints: "/usr/share/keys/pkg", enabled: yes } root@emby:/usr/local/lib/emby-server/lib # To see if it helped, I changed to latest and upgraded.ldd did not show any missing dependencies either, and the log from emby server still shows it can't find ImageMagick. (Attaching log). embyserver.txt
alucryd 318 Posted December 5, 2018 Posted December 5, 2018 Thanks for the feedback, I'm at a loss, will try to get more log out of emby about potential failures while trying to load ImageMagick.
makarai 109 Posted December 5, 2018 Posted December 5, 2018 (edited) Is the "libdl.so.1 => /usr/lib/libdl.so.1 (0x80479d000)" importatnt as i dont see them on my freenas or your freebsd installation ? Edited December 5, 2018 by makarai
adrianwi 279 Posted December 5, 2018 Posted December 5, 2018 It would be great if Canon .CR2 RAW files played nicely too
alucryd 318 Posted December 5, 2018 Posted December 5, 2018 @makarai: I would say no, it's not directly required by both imagemagick libs. It is a dep of libgomp from gcc though. I see that @marcelalolagos has libgomp.so.1 => /usr/local/lib/compat/libgomp.so.1, while I have /usr/local/lib/gcc6/libgomp.so.1 so this is why you don't see libdl.so. Do you have a gcc package installed? Just realized I still had gcc6 while regular gcc is available. I'll rebuild imagemagick with gcc 7. readelf -d libMagickWand-6.Q8.so Dynamic section at offset 0xde9a0 contains 38 entries: Tag Type Name/Value 0x0000000000000001 (NEEDED) Shared library: [libMagickCore-6.Q8.so.6] 0x0000000000000001 (NEEDED) Shared library: [libtiff.so.5] 0x0000000000000001 (NEEDED) Shared library: [libjpeg.so.8] 0x0000000000000001 (NEEDED) Shared library: [libpng16.so.16] 0x0000000000000001 (NEEDED) Shared library: [libfontconfig.so.1] 0x0000000000000001 (NEEDED) Shared library: [libfreetype.so.6] 0x0000000000000001 (NEEDED) Shared library: [libwebpmux.so.3] 0x0000000000000001 (NEEDED) Shared library: [libwebp.so.7] 0x0000000000000001 (NEEDED) Shared library: [libraw_r.so.16] 0x0000000000000001 (NEEDED) Shared library: [liblcms2.so.2] 0x0000000000000001 (NEEDED) Shared library: [libz.so.6] 0x0000000000000001 (NEEDED) Shared library: [libgomp.so.1] 0x0000000000000001 (NEEDED) Shared library: [libm.so.5] 0x0000000000000001 (NEEDED) Shared library: [libgcc_s.so.1] 0x0000000000000001 (NEEDED) Shared library: [libthr.so.3] 0x0000000000000001 (NEEDED) Shared library: [libc.so.7] readelf -d libMagickCore-6.Q8.so Dynamic section at offset 0x3542c0 contains 37 entries: Tag Type Name/Value 0x0000000000000001 (NEEDED) Shared library: [libtiff.so.5] 0x0000000000000001 (NEEDED) Shared library: [libjpeg.so.8] 0x0000000000000001 (NEEDED) Shared library: [libpng16.so.16] 0x0000000000000001 (NEEDED) Shared library: [libfontconfig.so.1] 0x0000000000000001 (NEEDED) Shared library: [libfreetype.so.6] 0x0000000000000001 (NEEDED) Shared library: [libwebpmux.so.3] 0x0000000000000001 (NEEDED) Shared library: [libwebp.so.7] 0x0000000000000001 (NEEDED) Shared library: [libraw_r.so.16] 0x0000000000000001 (NEEDED) Shared library: [liblcms2.so.2] 0x0000000000000001 (NEEDED) Shared library: [libz.so.6] 0x0000000000000001 (NEEDED) Shared library: [libm.so.5] 0x0000000000000001 (NEEDED) Shared library: [libgomp.so.1] 0x0000000000000001 (NEEDED) Shared library: [libgcc_s.so.1] 0x0000000000000001 (NEEDED) Shared library: [libthr.so.3] 0x0000000000000001 (NEEDED) Shared library: [libc.so.7] @@adrianwi RAW support is needed for DNG so you should get it as well when this works as expected. 1
makarai 109 Posted December 5, 2018 Posted December 5, 2018 I might give it a try, as there are some issues in the recent beta that might be related to imagemagick.
makarai 109 Posted December 5, 2018 Posted December 5, 2018 (edited) @@Luke @@alucryd after i installed gcc7 (pkg install gcc7) on my freenas Jail the speed issue (of displaying images) seems to be gone. Not sure if the actual bug is fixed or if its just a random fluke. But what i describe here https://emby.media/community/index.php?/topic/66010-36073-movie-list-loading-slow/ is not present. Also my list is root@emby-server-beta74:~ # cd /usr/local/lib/emby-server/lib/ root@emby-server-beta74:/usr/local/lib/emby-server/lib # setenv LD_LIBRARY_PATH /usr/local/lib/emby-server/lib root@emby-server-beta74:/usr/local/lib/emby-server/lib # ldd libMagickWand-6.Q8.so.6.0.0 libMagickWand-6.Q8.so.6.0.0: libMagickCore-6.Q8.so.6 => /usr/local/lib/emby-server/lib/libMagickCore-6.Q8.so.6 (0x801400000) libtiff.so.5 => /usr/local/lib/libtiff.so.5 (0x80195e000) libjpeg.so.8 => /usr/local/lib/libjpeg.so.8 (0x801bd8000) libpng16.so.16 => /usr/local/lib/libpng16.so.16 (0x801e6b000) libfontconfig.so.1 => /usr/local/lib/libfontconfig.so.1 (0x8020a6000) libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x8022ee000) libwebpmux.so.3 => /usr/local/lib/libwebpmux.so.3 (0x8025a5000) libwebp.so.7 => /usr/local/lib/libwebp.so.7 (0x8027af000) libraw_r.so.16 => /usr/local/lib/libraw_r.so.16 (0x802a3e000) liblcms2.so.2 => /usr/local/lib/liblcms2.so.2 (0x802d3a000) libz.so.6 => /lib/libz.so.6 (0x802f99000) libgomp.so.1 => /usr/local/lib/gcc7/libgomp.so.1 (0x8031b1000) libm.so.5 => /lib/libm.so.5 (0x8033dd000) libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x80360a000) libthr.so.3 => /lib/libthr.so.3 (0x803819000) libc.so.7 => /lib/libc.so.7 (0x800823000) liblzma.so.5 => /usr/lib/liblzma.so.5 (0x803a41000) libjbig.so.2 => /usr/local/lib/libjbig.so.2 (0x803c6a000) libexpat.so.1 => /usr/local/lib/libexpat.so.1 (0x803e77000) libbz2.so.4 => /usr/lib/libbz2.so.4 (0x8040a1000) libc++.so.1 => /usr/lib/libc++.so.1 (0x8042b5000) libcxxrt.so.1 => /lib/libcxxrt.so.1 (0x804583000) libdl.so.1 => /usr/lib/libdl.so.1 (0x8047a2000) root@emby-server-beta74:/usr/local/lib/emby-server/lib # is now quite similar. Edited December 5, 2018 by makarai
makarai 109 Posted December 5, 2018 Posted December 5, 2018 (edited) @@marcelolagos Also for me at least DNG files are NOW displayed: Sources https://www.camerafv5.com/pages/raw-samples.php http://www.rawsamples.ch/index.php/en/canon Also @@adrianwi cr2 also displays Edited December 5, 2018 by makarai 1
alucryd 318 Posted December 5, 2018 Posted December 5, 2018 @@makarai Great! Thanks for testing, I'll add a dependency on the gcc7 package then.
alucryd 318 Posted December 5, 2018 Posted December 5, 2018 That said, I'll try disabling openmp first so that you don't have to install gcc at all.
alucryd 318 Posted December 5, 2018 Posted December 5, 2018 Could you guys give this one a try? https://paste.xinu.at/e3Vyx/ This is built without openmp and doesn't link against libgomp.so.
makarai 109 Posted December 5, 2018 Posted December 5, 2018 Could you guys give this one a try? https://paste.xinu.at/e3Vyx/ This is built without openmp and doesn't link against libgomp.so. I just saw this give me a couple of minutes
makarai 109 Posted December 5, 2018 Posted December 5, 2018 @@alucryd The version works fine, I am quite sure my movie library runs the same speed and all the test images i included are displayed after some initial internal converting i suppose. embyserver.txt ffmpeg-remux-202d49e5-8e66-4667-959e-f7d4b7fc4f95_1.txt hardware_detection-63679625279.txt
alucryd 318 Posted December 5, 2018 Posted December 5, 2018 Awesome, thx! I guess we can live without openmp then, we'll go with that.
makarai 109 Posted December 5, 2018 Posted December 5, 2018 (edited) Awesome, thx! I guess we can live without openmp then, we'll go with that. What is openmp for, usually? It's i guess for parallelization, whatever that means I have not done an in depth performance review, in terms of how much the cpu is utilized and so on cause i am probably not the right person for that Edited December 5, 2018 by makarai
alucryd 318 Posted December 5, 2018 Posted December 5, 2018 It's for parallelization, see https://imagemagick.org/script/openmp.php It's not an end-all be-all speed improvement though and in some cases it won't even help at all. If we are satisfied with the current speeds, a more portable build is preferable. If we do need the extra speed, it's worth considering in the future though, if skia with dng support is not a thing on freebsd by then that is.
Luke 42239 Posted December 5, 2018 Posted December 5, 2018 It's better for Emby server to not have openmp anyway. It will already be using multiple threads for simultaneous image processing. When that happens it is best to keep each on it's own single thread.
marcelolagos 1 Posted December 6, 2018 Author Posted December 6, 2018 Could you guys give this one a try? https://paste.xinu.at/e3Vyx/ This is built without openmp and doesn't link against libgomp.so. Awesome!. This one worked perfectly, without installing gcc7. It can display DNG files now. Thank you! I will install gcc7 anyways as @@makarai mentions it will improve performance.
makarai 109 Posted December 6, 2018 Posted December 6, 2018 Awesome!. This one worked perfectly, without installing gcc7. It can display DNG files now. Thank you! I will install gcc7 anyways as @@makarai mentions it will improve performance. Did i? i dont think i did. We more or less problemsolved your problem, by testing some of these things. The beta 74_1 and 74 + gcc show the same performance.
makarai 109 Posted December 6, 2018 Posted December 6, 2018 @@alucryd is the _75 version basically an updated version that addresses all the issues discussed here in the thread?
