Noel Grassy 42 Posted September 2, 2018 Posted September 2, 2018 I ran into a problem playing movies with beta sever version 3.6.0.32 in kodi Leia beta 1. I am using emby beta plugin as well. TV shows play fine but movies will not play at all. If I long press on the movie icon in kodi a menu comes up with one entry that says "force transcode". If I press that it will play. Also after editing the database number manually from 110 to 112 it resets back to 110 in the emby addon database.py. https://paste.kodi.tv/rijaweriqi
Solution Angelblue05 4132 Posted September 2, 2018 Solution Posted September 2, 2018 Check your log, search for : CVideoPlayer::OpenInputStream Is the path is correct? Kodi is complaining about the file. Has nothing to do with the add-on itself, unless the path is incorrect. 1
Noel Grassy 42 Posted September 2, 2018 Author Posted September 2, 2018 You're right. I messed up and put a space where it shouldn't have been. Thank you very much! I suppose i'll have to repair local database in kodi to fix it though because they still aren't playing. On another note, anytime i ope music in kodi it tells me it needs to rescan tags from files? Is this a known problem or did i screw up again? https://paste.kodi.tv/ofoyabiwak 1
Angelblue05 4132 Posted September 2, 2018 Posted September 2, 2018 (edited) Thanks, that music issue will be fixed. Don't know if with the next beta. I'm hurrying it up If you use native playback mode, then yes you'll need to repair your database. Edited September 2, 2018 by Angelblue05 1
KrX3D 0 Posted September 3, 2018 Posted September 3, 2018 hi, im just asking, is it the same or simular problem i´m getting here?: https://emby.media/community/index.php?/topic/62192-emby-on-libreelec-9-newer-builds-doesnt-update-library/
Noel Grassy 42 Posted September 3, 2018 Author Posted September 3, 2018 hi, im just asking, is it the same or simular problem i´m getting here?: https://emby.media/community/index.php?/topic/62192-emby-on-libreelec-9-newer-builds-doesnt-update-library/ I don't think so. I just typed a network path wrong in the library setup.
