poerlemans 5 Posted October 1, 2018 Posted October 1, 2018 @@solabc16 Good day James, I would like to test the new beta version on my DS918+. I have already the stable Emby version (3.5.3.0) running on this machine. I understand that both a stable Emby version and a beta Emby version can be installed parallel to each other on the same machine. But that only one of both versions should run. In case you expect that problems may arise, I can also install the beta version on a DS216+ Peter
dknaack 0 Posted October 4, 2018 Posted October 4, 2018 I'd very much like to test this too please. I have a DS218+.
AlwinHummels 134 Posted October 4, 2018 Posted October 4, 2018 Hi James, Would like to test .NET Running DS415+ with Emby server Versie 3.6.0.2 beta
oRBIT 0 Posted October 4, 2018 Posted October 4, 2018 Hi, I'd like to test the new version aswell. I'm on a DS918+ user with 12GB of RAM. What can I expect to the .NET core version compared to the "regular" version?
solabc16 379 Posted October 5, 2018 Author Posted October 5, 2018 Hello @@oRBIT There are a few drivers behind the move to .NET core, one of which is performance; which we expect to improve and continue to improve over time. Having said that, it is likely to be workload specific and the performance gap to Mono has reduced, thanks to the collective community efforts. The are efficiencies to be gained on the development side, as it makes support for various platforms a little easier and potentially more robust; see threads on the real-time monitoring as an example. Best - James
solabc16 379 Posted October 5, 2018 Author Posted October 5, 2018 (edited) Hello @@oRBIT, @@AlwinHummels, @@dknaack, @@poerlemans, @@jasondeb17 Thanks for offering to help test the upcoming .NET Core release of Emby Server on Synology. I've sent you an invite to the group. * Please make sure to start at the beginning and read the first couple of posts on the PM! Best - James Edited October 5, 2018 by solabc16
Kalua85 0 Posted October 5, 2018 Posted October 5, 2018 @@solabc16 You forgot me I can test Evansport package (DS214play)
solabc16 379 Posted October 5, 2018 Author Posted October 5, 2018 Hello @@Kalua85 Sorry, I didn't forget you. Thanks for your interest, I've added you to the list so I can update you. We do not have a .NET Core package available for the 'evansport' architecture yet. Best - James
solabc16 379 Posted October 5, 2018 Author Posted October 5, 2018 (edited) Hello @@EagleMitchell Thanks for offering to help test the upcoming .NET Core release of Emby Server on Synology. I've sent you an invite to the group. * Please make sure to start at the beginning and read the first couple of posts on the PM! Best- James Edited October 5, 2018 by solabc16
alanr 0 Posted October 6, 2018 Posted October 6, 2018 Hi, I have a DS418play and would be happy to test a .NET release of Emby, which is used for many hours each day. Regards Alan
solabc16 379 Posted October 6, 2018 Author Posted October 6, 2018 Hello @@alanr Thanks for offering to help, I've sent you an invite to the group - please make sure to start at the beginning and read the first couple of posts on the PM! Best- James
Spidey74 0 Posted October 6, 2018 Posted October 6, 2018 Hi James, I recently upgraded to a DS918+ with 8GB of RAM and am very interested to test the .NET core as I am reinstalling everything here. Can you please also add me to the test group for the apollolake version? Regards, Edwin
solabc16 379 Posted October 10, 2018 Author Posted October 10, 2018 (edited) Hello @@Spidey74 Sorry for the delay in responding, there was an issue introduced with beta 3.6.0.52 that we wanted to resolve before bringing any more testers on board. Thanks for offering to help, I've sent you an invite to the group - please make sure to start at the beginning and read the first couple of posts on the PM! Best- James Edited October 10, 2018 by solabc16
numkem 0 Posted October 14, 2018 Posted October 14, 2018 Hello, I'd be more than happy to help out. I have a DS916+ with 8GB of ram. Thank you.
Everbrave 62 Posted October 31, 2018 Posted October 31, 2018 VA-API used to work well with DS918+, but now it is no longer available in this server version (3.6.0.58), what is the appropriate HW selection of the Decoding method for DS918+? When is HW Encoding necessary to select, if at all? Thanks
Luke 42241 Posted October 31, 2018 Posted October 31, 2018 VA-API used to work well with DS918+, but now it is no longer available in this server version (3.6.0.58), what is the appropriate HW selection of the Decoding method for DS918+? When is HW Encoding necessary to select, if at all? Thanks Server log? Thanks.
Everbrave 62 Posted October 31, 2018 Posted October 31, 2018 (edited) Server log? Thanks. VA-API is not available as an option! The server log is attached as well as screen shots for the Web-UI. EDIT: I think the server lo I sent, log-11.txt, is from my Windows server, so please ignore this one. Log-11.txt Edited October 31, 2018 by Everbrave
solabc16 379 Posted October 31, 2018 Author Posted October 31, 2018 Hello @Everbrave As per the development/test thread, can you post a log from just after the server has started, so we can see the FFmpeg decoder/encoder detection. Best - James
Everbrave 62 Posted October 31, 2018 Posted October 31, 2018 Hello @Everbrave As per the development/test thread, can you post a log from just after the server has started, so we can see the FFmpeg decoder/encoder detection. Best - James here you go Log-13.txt Log-12.txt
solabc16 379 Posted October 31, 2018 Author Posted October 31, 2018 (edited) Hello @@Everbrave Unfortunately, these are still after a log rotation, rather than from when Emby Server is first started. When convenient, the best thing to do will be to restart Emby Server - which you can do from the dashboard, then grab the most recent log. Best - James Edited October 31, 2018 by solabc16
Everbrave 62 Posted October 31, 2018 Posted October 31, 2018 Hello @@Everbrave Unfortunately, these are still after a log rotation, rather than from when Emby Server is first started. When convenient, the best thing to do will be to restart Emby Server - which you can do from the dashboard, then grab the most recent log. Best - James done; hope these help. Log-14.txt Log-15.txt
softworkz 5133 Posted November 1, 2018 Posted November 1, 2018 VA-API is not available as an option! The server log is attached as well as screen shots for the Web-UI. EDIT: I think the server lo I sent, log-11.txt, is from my Windows server, so please ignore this one. This is rather a misunderstanding There's no missing or dropped functionality In the second screenshot you can see the "VAAPI H.264" encoder. That's all VAAPI support that has ever existed. Emby didn't have VAAPI accelerated decoding before. (Don't believe? Go to the transcoding settings of an older Emby version; select QuickSync or Nvenc and see the decoder checkboxes; select VAAPI => no decoder checkboxes) The only thing that is wrong here is that DXVA is shown. This will be fixed in the next version. PS: I can't make any announcements, but I can at least say that support for VAAPI decoding is under consideration ;-)
Everbrave 62 Posted November 1, 2018 Posted November 1, 2018 (edited) This is rather a misunderstanding There's no missing or dropped functionality In the second screenshot you can see the "VAAPI H.264" encoder. That's all VAAPI support that has ever existed. Emby didn't have VAAPI accelerated decoding before. (Don't believe? Go to the transcoding settings of an older Emby version; select QuickSync or Nvenc and see the decoder checkboxes; select VAAPI => no decoder checkboxes) The only thing that is wrong here is that DXVA is shown. This will be fixed in the next version. PS: I can't make any announcements, but I can at least say that support for VAAPI decoding is under consideration ;-) Well, that is interesting I, and many others, have been using VA-API for HW-transcoding and there are few threads on that; one is https://emby.media/community/index.php?/topic/51051-is-ds718-and-ds918-units-supported-yet-for-hw-transcoding/page-3 where James also confirmed it. So, there must be some misunderstanding, but which? Nevertheless, getting back to the original question, Which HW-transcoding method should currently be selected for DS918+? Thanks Edited November 1, 2018 by Everbrave
