keithterrill 2 Posted August 31, 2018 Posted August 31, 2018 Running Linux Mint 18. Emby came up in the browser but wouldn't work right. I uninstalled the emby server. I deleted the user and group for the emby. I created a new user and group for the emby. I downloaded emby-server-deb_3.5.2.0_amd64. I installed it using the debian installer. Now I cannot get it to come up in the browser. http://192.168.x.x:8096/ gives: This site can’t be reached192.168.1.134 refused to connect.
Luke 42246 Posted August 31, 2018 Posted August 31, 2018 Hi there, can you please attach the emby server log? thanks.
keithterrill 2 Posted September 1, 2018 Author Posted September 1, 2018 I cannot find a log. I don't believe the service started. I cannot figure out how to start it.
Luke 42246 Posted September 1, 2018 Posted September 1, 2018 Can you supply the complete terminal output? thanks.
tdiguy 99 Posted September 1, 2018 Posted September 1, 2018 I dont know if it is related but i remember someone else on the forum having an issue with emby that created the emby user first. If you dont mind humoring me delete the emby user, uninstall emby then re-install emby without making the emby user first.
Luke 42246 Posted September 1, 2018 Posted September 1, 2018 Thanks. Let's see what the full terminal output says.
tdiguy 99 Posted September 1, 2018 Posted September 1, 2018 I cannot find a log. I don't believe the service started. I cannot figure out how to start it. After it is installed it should start automatically, since it is having an issue the following commands might be useful: sudo service emby-server status sudo service emby-server start the default directory for emby logs might be: /var/lib/emby/logs but when it comes to linux things can vary from distribution to distribution. I imagine it would be useful to try sudo emby-server start and paste the output here.
keithterrill 2 Posted September 2, 2018 Author Posted September 2, 2018 After it is installed it should start automatically, since it is having an issue the following commands might be useful: sudo service emby-server status sudo service emby-server start the default directory for emby logs might be: /var/lib/emby/logs but when it comes to linux things can vary from distribution to distribution. I imagine it would be useful to try sudo emby-server start and paste the output here. Terminal output: director@AHC-TOWER ~ $ sudo service emby-server status [sudo] password for director: ● emby-server.service - Emby Server is a personal media server with apps on just about ever Loaded: loaded (/usr/lib/systemd/system/emby-server.service; disabled; vendor preset: en Active: failed (Result: signal) since Fri 2018-08-31 16:28:32 EDT; 1 day 3h ago Main PID: 4846 (code=killed, signal=ABRT) Aug 31 16:28:32 AHC-TOWER systemd[1]: Started Emby Server is a personal media server with a Aug 31 16:28:32 AHC-TOWER systemd[1]: emby-server.service: Main process exited, code=killed Aug 31 16:28:32 AHC-TOWER systemd[1]: emby-server.service: Unit entered failed state. Aug 31 16:28:32 AHC-TOWER systemd[1]: emby-server.service: Failed with result 'signal'. Aug 31 16:33:49 AHC-TOWER systemd[1]: Stopped Emby Server is a personal media server with a Aug 31 17:09:31 AHC-TOWER systemd[1]: Stopped Emby Server is a personal media server with a director@AHC-TOWER ~ $ sudo service emby-server start director@AHC-TOWER ~ $ sudo service emby-server status ● emby-server.service - Emby Server is a personal media server with apps on just about ever Loaded: loaded (/usr/lib/systemd/system/emby-server.service; disabled; vendor preset: en Active: failed (Result: signal) since Sat 2018-09-01 20:11:03 EDT; 4s ago Process: 1164 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=ABRT) Main PID: 1164 (code=killed, signal=ABRT) Sep 01 20:11:01 AHC-TOWER systemd[1]: Started Emby Server is a personal media server with a Sep 01 20:11:03 AHC-TOWER systemd[1]: emby-server.service: Main process exited, code=killed Sep 01 20:11:03 AHC-TOWER systemd[1]: emby-server.service: Unit entered failed state. Sep 01 20:11:03 AHC-TOWER systemd[1]: emby-server.service: Failed with result 'signal'. director@AHC-TOWER ~ $ I can ping the ip address which is myself, but... Still getting "This site can't be reached" There is no /var/lib/emby/ folder.
keithterrill 2 Posted September 2, 2018 Author Posted September 2, 2018 Thanks. Let's see what the full terminal output says. I am not sure what you are asking for. If I open the terminal.... then what?
Solution keithterrill 2 Posted September 2, 2018 Author Solution Posted September 2, 2018 I figured out the problem. The emby was not fully installing. It failed because when I uninstalled and then removed the user:group the group emby was left. It had a "hidden" user of emby. Logging in to a terminal and then running: $ sudo deluser emby $ sudo delgroup emby Then reinstalling the emby... that did the trick. At lest we are now scanning libraries. 1
