jasonmcroy 320 Posted August 30, 2018 Posted August 30, 2018 I have the DVR set to record "All Episodes" of Supernatural. It is playing back to back on TNT. It will record the first occurring episode but then the second, third and so on episodes it fails to record. I use this recording as an example but it did the same thing overnight with another show on a different channel. Here is the latest log (look at time 12:59 where failure occurs): embyserver.txt I have never seen any issues with recording new episodes and I usually don't record repeats but this was a test I was running for a different reason. I have another recording set up to start for a different show at 2:00pm. I will see how that one goes as well.
jasonmcroy 320 Posted August 30, 2018 Author Posted August 30, 2018 Now it doesn't seem to want to record anything and I can't tune to a channel using the Shield TV app. It says unable to play channels and suggests there may not be an available tuner, but they are all free and playback works fine from the native HDHomerun App. Another log for you: embyserver.txt
Solution PenkethBoy 2068 Posted August 30, 2018 Solution Posted August 30, 2018 try rebooting the emby server to free up the tuner slots on the server 1
jasonmcroy 320 Posted August 30, 2018 Author Posted August 30, 2018 try rebooting the emby server to free up the tuner slots on the server I just rebooted and I set up two more recordings to happen at 6:00. We'll see how it goes. Weird that I have never had this issue with Emby before.
PenkethBoy 2068 Posted August 30, 2018 Posted August 30, 2018 sometimes the tuners get messed up in emby even though they are avaiable outside emby there is a need for management functions 1
jasonmcroy 320 Posted August 30, 2018 Author Posted August 30, 2018 sometimes the tuners get messed up in emby even though they are avaiable outside emby there is a need for management functions Thanks. It seems to be recording correctly now. I haven't been using Emby for recording in a little while but now that I have the Premium TV service from Silicondust and my OTA channels I think I want to go back to Emby doing everything since the ability to see what recordings are upcoming and on going is much easier to do in Emby than via SD's software. In the past times I have used it though I never had that happen. Is this something that happens often though? I'd hate to miss some of my actual recordings (today were just test recordings of nothing important) because this occurred.
PenkethBoy 2068 Posted August 31, 2018 Posted August 31, 2018 its occasionally - have not seen a pattern
jasonmcroy 320 Posted August 31, 2018 Author Posted August 31, 2018 Ok, thanks. I will just have to keep an eye on it.
maegibbons 1287 Posted August 31, 2018 Posted August 31, 2018 @@Luke is introducing some more logging to try and track down non-recording issues. Krs Mark
