marauder 18 Posted August 30, 2018 Posted August 30, 2018 I’ve been trying to sync files to me device. And they randomly keep freezing when converting or sending to the device. It will just say queued but nothing else is trying to transfer. These are all to iOS latest 11 release devices on latest release 3.5.2
Luke 42246 Posted August 30, 2018 Posted August 30, 2018 Hi, how exactly have you determined that they're freezing? Thanks.
marauder 18 Posted August 30, 2018 Author Posted August 30, 2018 Hi, how exactly have you determined that they're freezing? Thanks. The screenshot showing the progress is always the same. Itll still say queued a couple hours later but there’s no other transfers or converting going on.
Luke 42246 Posted September 1, 2018 Posted September 1, 2018 hi @@marauder, the issue is just the progress reporting needs to be improved. there are times when it will stay at 0% and that might lead you to think that it's stuck. The downloads will happen though. Thanks.
